Old 10-24-2010, 11:31 AM   #1
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
Frame Damage under battery compartment
Bought a 1988 Excella that looks good. Except, when I checked out the rust where the left front frame member enters the trailer under the battery compartment. The frame is rusted through at the bottom and one side.
How can this be repaired? My thought is that maybe a local welding shop could cut out the damaged part and weld back in a new tube. Or perhaps weld supports along the side and bottom?
Can they weld to it with the wooden floor above, or what???
Perplexed and a little unhappy.
Bill
Old 10-24-2010, 12:39 PM   #2
1962 16' Bambi
2001 31' Limited
1985 29' Sovereign
Jenison , Michigan
Images: 8
Andy......we need YOU!
62bam is offline   Reply With Quote
Old 11-16-2010, 11:14 AM   #3
1988 25' Excella
1987 32' Excella
Not a lot of help on this one do I see. So I get to update my own post. I rigged up a brace for the really rusty area out of channel iron and ubolts and towed the rig to Jackson Center. Repar is going to consist of replacing the whole A assembly and some work on one frame member.
When you buy an Airstream, be sure to check out this area better than I did. Or budget an extra three grand and a couple of tows to and from Jackson Center in case you make a mistake. It looked rusty, but the original paint and caulking to the banna skirt hid the deeper damage. I pried out the caulk and started to scrape it to paint and a whole sheet of the surface of the frame with the paint attched fell off revealing the rust through the frame. It was also very rusty under the front belly pan. Main frames looked okay.
We had the option of fixing it right or bracing it up and using it as a park model. We like it well enough to go ahead and get it repaired. Had a broken fresh water tank also. I am now well over budget for repairs. I would like to be able to weekend with it even though it will be parked on a lot in Fl most of the year.
Old 11-16-2010, 11:22 AM   #4
Your question?
Old 11-16-2010, 11:23 AM   #5
You did good by having Jackson Center do the repair.
Just saw your post.
Battery Compartment Sundance Batteries, Univolts, Converters & Inverters 10 07-14-2007 11:56 AM
Battery compartment doors nwclassic Our Community 5 10-03-2004 08:28 PM
Door hinge/frame damage Dennis Fahlstrom Doors & Locks 1 07-04-2003 11:50 AM
Battery compartment...How to? Rog0525 Electrical - Systems, Generators, Batteries & Solar 4 06-17-2003 10:58 PM
battery compartment mods nwclassic Our Community 13 02-18-2003 06:46 AM
