Old 04-06-2003, 07:06 AM   #1
klanke
Profile:
Rivet Frame Damage (Rust under water Tank
I purchased a 71 Landyachet .. 12 Years ago, out of a junk yard, she was headed fore the shearder, I have had her now for 12 Years, the family and I have enjoyed this old trailor.
Last summer our frame break just aft of the rear wheel(under) the hot water heater, I have wanted to do some reserasation work and **here's my chance.. This is some-what complex, has anyone had experance with this kind of repair, What's it going to take??
She's all there, with the exception of the recent damage!
klanke is offline   Reply With Quote
Old 04-06-2003, 08:25 AM   #2
pap
Profile:
Hey Klanke good move on the junk yard reprieve.
You like so many here have given us too little info to do much comment on your problems.
It would be nice if we at least knew what size and floorplan your Airstream happens to be.
Landyacht is usually referring to a class (i.e.an option package) instead of a model.
There is much on this forum regarding broken frames. Search under tail sag, or tail droop, or rear end separation.
You also fail to tell us where you are, but if you are stateside and near Ohio you can get it done at the factory.
Just curious why you chose not to list a location on your profile?
Best of luck.
pap is offline   Reply With Quote
Old 04-06-2003, 08:27 AM   #3
garry
garry's Avatar
Profile:  1969 31' Sovereign
Broken Arrow , Oklahoma
Must be a rear bath ?
AS has a kit that prevents this from happening. I had the kit installed as soon as I noticed a buckel at the rear wheel area.
I had the work done by an AS shop in Oklahoma City..
A local shop that works on AS's said they never install the kit but weld a homemade support bracket onto the frame. I did not trust the homemade fix. I think the kit is around $700.
I think Andy will know the answer to this one. But my take is once the frame brakes/separates you will be looking at some frame welding.
Garry
garry is online now   Reply With Quote
Old 04-06-2003, 08:34 AM   #4
Chas
Chas's Avatar
Profile:  Austin , Texas
Images: 22
Sounds pretty bad to me. If the frame is indeed rusted so extensively to the point of breaking I wonder if there is enough substantial metal left to get it rewelded correctly?
Chas
Chas is offline   Reply With Quote
New clean water tank silver suz Fresh Water Systems 19 03-29-2004 08:16 PM
fresh water tank filling system nickcrowhurst Fresh Water Systems 5 03-16-2004 12:37 PM
Why not grey water into black tank? pilgrim_still Waste Systems, Tanks & Totes 40 10-08-2003 07:59 PM
Could Water Heater Tank Be Filled with Junk? heyskipper Water Heaters, Filters & Pumps 4 03-17-2003 07:26 AM
1978 Minuet 6.0 Metre Gray Water Tank overlander64 All Argosy Trailers 6 11-15-2002 06:11 AM
