Old 02-06-2016, 01:52 PM   #1
1961 16' Bambi
Shoreline , Washington
Frame cross members
I'm the proud owner of a 1961 Bambi and plan on doing some upgrades that involves installing flush mount, recessed well pedestal leg bases in the floor and want to avoid hitting the cross members when I drill. I'm looking for information / plans on where the cross members in the frame are. I have a general idea by looking underneath at the belly pan and seeing where the pan is riveted. Would that be a reliable guide and does anyone know how wide the cross members are?
Thanks, Kelly.
Kelly11 is offline   Reply With Quote
Old 02-06-2016, 02:09 PM   #2
JimGolden's Avatar
1977 31' Excella 500
Best thing is to just remove the belly pan. Then you'll know exactly where everything is.
Besides, on a trailer that old, it would be a good idea to inspect the frame and cross members anyway. It's very easy to pull the belly pan. Just drill out the rivets and replace them later with sheet metal screws.
Best of luck,
- Jim
JimGolden is offline   Reply With Quote
Old 02-06-2016, 03:25 PM   #3
Thanks, Kelly.
Kelly.
Your best and only chance, is to look at the underbelly rivet locations.
Old 02-06-2016, 04:41 PM   #4
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
Welcome to the Forums!
You ought to be able to find them quite easily with a conventional stud finder. Even better would be one of those older, and simple stud finders that were just based on a magnet on a bit of a pendulum that reacted to the magnetic nails in the studs. Just be wary that you may have tanks under your floor, depending on what previous owners may have installed, as well as plumbing (drainage pipes).
good luck!
Old 02-06-2016, 05:25 PM   #5
Images: 59
I think the crossmembers are 1 1/2" wide. The magnet idea should work great as the elevator bolt heads are about 1 inch wide.
I'd start with a small finger sized hole, then probe around with a coat hanger to be sure. There shouldn't be any tanks under the floor in a '61 model.
Old 02-07-2016, 11:49 AM   #6
1961 16' Bambi
Thanks to all who took the time to reply to my questions with sound advice. Even though I've owned and worked on this trailer for a number of years, this was my first time to use this forum as a resource and I'll definitely do it again.
Kelly
Old 07-21-2017, 05:11 PM   #7
Gatineau , Quebec
insulating cross members
Need your advice with this silly idea... I am doing a full off shell renovation. While the frame is being repaired, I am wondering what I will do with the holes in the frame. As I am also thinking about floor insulation, it occurred to me that perhaps if I insulated with spray foam (closed cell) the cross members through the whole, they might be less conducive to cold and heat. Any views on this. Is there any counter indications to filling the cross members with closed cell foam?
Juliec is offline   Reply With Quote
Does a 3" cross pipe belong in back frame? capt ken Repairing/Replacing Floor &/or Frame 1 10-22-2014 07:57 PM
Cross Section of Walls to frame? big-boss Repairing/Replacing Floor &/or Frame 1 08-11-2010 11:19 AM
Cross Member of frame Joe1261 Repairing/Replacing Floor &/or Frame 2 01-17-2007 09:16 PM
cross members loose?? tomcook Repairing/Replacing Floor &/or Frame 4 03-11-2006 11:43 AM
Are Forum members WBCCI members? 83Excella WBCCI Forum 8 07-03-2002 12:37 AM
