Old 08-05-2005, 04:05 PM   #1
Commercial Vendor
Profile:  Corona , California
A-frame cracks
Frame cracked? Abusive use? Nah, you can do anything to the frame of an Airstream.
Don't bet on it.
Heavy duty tow vehicle towing an Airstream trailer without any wheel balancing, can result it severe damage to the frame.
The attached photo show an A-frame, cracked almost in half.
The frames on older trailers should be frequently checked for cracks.
The old frames were channel steel, not boxed steel, therefore they can fatigue must faster.
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
Old 08-05-2005, 04:20 PM   #2
norbert's Avatar
Profile:  1993 30' Excella
chicagoland , state of confusion+north of cheddar curtain
Images: 24
very scary
what years are we talking about?
Illegitimous noncarborundum(dont let the bastards wear you down)
The only true nobility is found through giving good food to your friends- Anton Careme
beauty is in the eye of the beerholder-cosmo fishhawk
if something is too good to be true, its usually gone before i get there-mister boffo
norbert is offline   Reply With Quote
Old 08-05-2005, 04:22 PM   #3
Commercial Vendor
All the years that used channel steel.
Inlandrv.com
Old 08-05-2005, 04:32 PM   #4
Janet's Avatar
Profile:  Eastern , Washington
Images: 63
Which years used channel steel?
77 Argosy Minuet, 6 metre
77 Argosy 24, Rear door
AIR 3181, WBCCI/VAC # 5575
Wally knows: AIRForums.com is the best place to camp!
Janet is offline   Reply With Quote
Old 08-05-2005, 04:39 PM   #5
greg176's Avatar
Profile:  1961 26' Overlander
Gabriola Island , British Columbia
I know my '61 did.Thanks for posting photo,always interested.It looks like corrosion of the upper chord of the channel played a part in the eventual failure.That is why I opted for replacing my frame.
http://www.airforums.com/forum...t=frame+repair
greg176 is offline   Reply With Quote
Old 08-05-2005, 05:14 PM   #6
greg176's Avatar
Andy, I enjoyed your article in Airstream Life on towing and hope to read another some time soon.
I am currently in the market for a pickup.As I will be building a house on the island I was thinking if an F-250 for hauling.Do you think it would be better for the Airstream if I went with an F-150.
Old 08-09-2005, 05:46 PM   #7
Moderator dude
Action's Avatar
Profile:  1966 26' Overlander
Phoenix , Arizona
Images: 13
Several posts of this thread were cut and moved to the Community Forum under towing. The title of that thread is called "Tow Vehicles"
Now we resume the regularly scheduled thread called "A-frame cracks"
Thank you.
>>>>>>>>>>>>Action
1966 Mercury Park Lane 4 DR Breezeway 410 4V, C-6, 2.80 - towing a - 1966 Overlander International Twin Bed
1996 Lincoln Mark VIII Diamond Anniversary 4.6L (275hp), 4R70W - 1990 Ford E 150 5.7L, AOD, 3.73 ____________________________________
Phoenix ~ Yeah it's hot however it's a dry heat!
Old 08-11-2005, 09:28 PM   #8
greg176's Avatar
I used to use the wheel balancer that Andy uses to balance Boeing 737 nosewheels at Nordair.Snap On no longer carries it.If you want to do it yourself here is a helpful link.
http://members.tripod.com/ronkilber//BALANCER.HTM
Pingbacks are On
Oval Window Frame Replacement MikeMikeMI Windows & Screens 8 12-30-2007 10:49 AM
yr frame size reduced yukonsilver Airstream Trailer Forums 1 04-19-2004 12:53 PM
Window Frame Replacement Charles D. Bennett Windows & Screens 20 08-16-2002 06:03 PM
Window Frame Removal 64GT Windows & Screens 4 04-09-2002 12:40 PM
SEO by vBSEO 3.1.0
