09-24-2018, 01:18 PM
2005 22' Safari
Denver
Cracked Frame Need Repair Shop
looking for a repair shop in Denver that will repair or potentially replace my cracked frame in Denver. Any help would be appreciated
09-24-2018, 01:31 PM
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Hi
Where is the crack and how bad is it?
In most cases:
Frame repair = expensive, but do-able.
Frame replacement = yikes !!!!!
09-24-2018, 01:50 PM
Try Iron Bear Trailer, formerly Jim’s Repair just east of the Merchandise Mart off of 58th east ofcWashington St. phone is 303-297-0339. Or option two: is Merrill Automotive, 16th and Yarrow, Lakewood ph 303-237-8846. They replaced our axles on an Overlander.
JIM n CHRIS
‘62 Overlander 26 ft. ATW Yeager trailer #5289
"62 Airstream 22ft. ATW Hall trailer #83,’90 SQ Sream, ‘06 Bambi Q/S, Prevost Featherlite 45ft, GMC/ Bigfoot camper
09-24-2018, 02:29 PM
2005 22' Safari
Denver
Hi
In most cases:
I have attached the image of the crack
09-24-2018, 02:48 PM
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Hi
Ok, that's a repair rather than a replace. With anything like this, there is a bit of digging into the "what happened?" part of it. You could have axle / hub / wheel damage if the root cause is hitting something major.
The process involves pulling everything off of the affected area and welding the frame to fix it. One can only tell so much from a picture. I'd guess there will be more than a little disassembly involved in this case.
Rather than drive around asking questions, I'd get on the phone and see who in the area is willing to take the project on. A couple more pictures from other angles might help them make that decision. You may be in for a wait if they are booked up ....
09-24-2018, 03:06 PM
2005 22' Safari
Denver
Thanks I will give them a call now
09-24-2018, 03:07 PM
2005 22' Safari
Denver
Hi
Good to know thanks for the info
09-24-2018, 03:15 PM
1971 21' Globetrotter
Arvada
09-24-2018, 04:00 PM
2005 22' Safari
Denver
Both these shops have already been more helpful then everyone I have been calling thanks again for the recommendation
10-04-2018, 06:04 PM
demijac
2014 27' FB Classic
Livingston
Call Timeless Travel Trailers in Wheat Ridge. Their Airstream knowledge is unsurpassed.
10-04-2018, 06:39 PM
2014 25' FB Flying Cloud
Des Peres
, Missouri
That looks like a very odd frame crack
How do you find it ?
