Old 10-07-2006, 10:11 AM   #1
1976 27' Overlander
Huachuca City , Arizona
frame crack
Someone asked for a pic of the frame crack on our '76 overlander. It was just aft of the rear axle. Since had it welded. Might reinforce once new axles and shocks are in place. I think the rear bath, tanks and worn out axles were the cause.
Name:	frame crack.jpg
jimnsue is offline   Reply With Quote
Old 10-07-2006, 10:20 AM   #2
1960 24' Tradewind
Riverside , California
Frame Crack
Airstream has a frame doubler kit available for this situation.
ZoomZoom
ZoomZoom is offline   Reply With Quote
Old 10-07-2006, 09:25 PM   #3
1976 27' Overlander
Question frame doubler?
Would that be available thru Airstream dealers or somewhere like inland RV?
jimnsu is offline   Reply With Quote
Old 10-07-2006, 09:46 PM   #4
1960 24' Tradewind
santa barbara , California
Hello jimnsue ,
Absolutely get the frame kit from airstream .A crack like that even when welded will crack right down the weld or most likely next to it .You can't just run a bead of weld on a frame .There are specific procedures to adhere to
when repairing a crack ,especially one that runs verticle as that crack does .
The weight of your coach has caused that crack as well as impact from
worn axles bottoming out ,you can see it is wider at the top as if the frame
is pulling it open ,and it is .The doubler kit will reinforce the frame front to
rear spreading the load .There will not be stress then at that crack point.
the frame is bent at that point ,so raising the rear of the trailer up to unload
that stressed area and having the frame reinforced is critical .When you raise
the rear up it will cause the frame to try to bend back up straight .Any way
long post ,but take this seriousely its a problem .
Scott of scottanlily
scottanlily is offline   Reply With Quote
Old 10-07-2006, 09:50 PM   #5
1960 24' Tradewind
I want to say that the weight I mentioned is from rear bath and full tanks
excessive weight hanging on the rear of the trailer .
Scott
Old 10-07-2006, 10:23 PM   #6
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
I would think that any vintage friendly Airstream Dealer should be able to get it for you. Try Ace Fogdal in Waterloo, IA or Out-of-Doors Mart in Colfax, NC. There are others but these are two that I have experience with.
Aaron
WBCCI #XXXX AIR #2495
Old 10-09-2006, 09:56 AM   #7
1976 27' Overlander
Thanks for the doubler information and sites.
Will check on them next.
BTW, here is a pic with the wheel covers we got with our airstream. Have you ever seen any others like them?
Old 10-09-2006, 10:25 AM   #8
Mad1
1989 29' Excella
Dallas , Texas
yep, previous owner of my '89 Excella said they were custom made for each trailer by someone that attended Airstream rallies and events years ago, may still be available for all I know.
http://tinyurl.com/ztpmy
madrone is offline   Reply With Quote
Oval Window Frame Replacement MikeMikeMI Windows & Screens 8 12-30-2007 10:49 AM
Frame crack Creampuff 1966 - 1968 Safari 4 11-03-2004 01:53 PM
year frame size reduced yukonsilver Airstream History 1 04-19-2004 12:53 PM
Cracked door frame 77caravaner Doors & Locks 5 10-11-2002 06:43 AM
Window Frame Removal 64GT Windows & Screens 4 04-09-2002 12:40 PM
