Old 08-24-2014, 09:17 AM   #1
RADINFLATROC's Avatar
Flatrock , Indiana
Frame Compromised
Has the frame been compromised.
Is this tank installation needing to be redone.... looks pretty jerry-rigged to me
Thanks in advance for your input
"Make it a Signature Day!"
RADINFLATROC is offline   Reply With Quote
Old 08-24-2014, 09:19 AM   #2
r carl's Avatar
Lin , Ne
Yes
You have no choice.
Old 08-24-2014, 09:23 AM   #3
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
I can't believe it! I just can't believe it. Yes, replace it and look around for more work done by the same person...I hope it was not you.
Old 08-24-2014, 09:23 AM   #4
Flatrock , Indiana
I don't follow, I am focused on the girder or front to back steel support that appears to have been cut.
Old 08-24-2014, 09:30 AM   #5
Flatrock , Indiana
Let me clarify
1. I am concerned as to the disruption in the steel support that runs front to back. It appears to have been cut
2. I am concerned with the tank replacement that was done. From the photo it just looks porly done.
I am looking at this 76 Argosy to purchase. I asked for pictures so I could determione the condition of the underside to review before I consider traveling 3.5 hours to see it first hand. If this picture is indicates a compromising situation I would rather pass on the trip and potential purchase and continue my search.
Hope this amplification helps
Thank you
Old 08-24-2014, 09:34 AM   #6
Stefrobrts's Avatar
1968 17' Caravel
Battle Ground , Washington
Images: 50
You might want to continue your search. That does not look like a well done job to me, I've never seen anything like it.
Stephanie
Old 08-24-2014, 09:40 AM   #7
1994 34' Excella
Warren , Manitoba
It does not look like any frame modification, however, the tank replacement is very poor. Have a look at the rest of the unit, and if possible, take someone that knows Airstreams with you. You never know, it might be a great deal. I have driven farther to look at units, and come home empty handed.
CBWELL is offline   Reply With Quote
Old 08-24-2014, 09:50 AM   #8
Flatrock , Indiana
Thank you, I appreciate the advice. Been searching long enough to know the AS Forum is like Dorothy Once Said " There's No Place Like Home! Good Advice
The retro work one sees in the older Airstreams is remarkable at times, and at other times, well lets just say their not engineering marvels.
I will continue to practice a old wise verse as I apply to my Airstream quest... " Seek and Ye Shall Find"
Old 08-24-2014, 10:46 AM   #9
Missouri Valley , Iowa
RAD
The rear frame on my 30' '02 Classic has the same "missing link". The area around the axles is for mounting and strength. The rear flange area, as I understand, is the rear end drag protection.
Dan
Farmer Dan is offline   Reply With Quote
Old 08-24-2014, 12:35 PM   #10
dznf0g's Avatar
Oswego , Illinois
Are you talking about the broad flat piece in the center running front to back?
If so, although it probably offers some structural integrity to the frame, I believe its main purpose is to provide a mounting platform for the floor as well as provide a more solid walking surface down the center isle. You can see in the picture, a couple sections are just bolted in place.
I would remove the.....whatever PO thought that was......and weld back a piece simulating what was there. I doubt you have compromised frame damage. Is there any reason to suspect...like buckled and wavy, or torn body skin, or a lot of missing rivets?
-Rich-
Old 08-24-2014, 01:37 PM   #11
RM66caravel's Avatar
1966 17' Caravel
Newport , North Carolina
As you look at the one photo it does not appear to be cut but possibly reinforced! Looking at the axle the frame rails appear to extend down below the axles and the belly pan sits 2 inches above the frame rails. The tank looks more like a storage tube meant to be in a closet in the house not in a trailer! There are no tank supports in that area unless added by the PO so you and we would need more input or pictures it could be a golden opportunity and a lets say poor choice of photos! Inside over that area and from the rear under the trailer and an outside shot or two. How one maintains the trailer tells a story too!
Cliff
Gotta get busy! Have a great day! Now where did I put those revits?
RM66caravel is offline   Reply With Quote
Old 08-24-2014, 02:24 PM   #12
rideair's Avatar
There's good and bad, the good: if it's a black or gray tank after driving down the road a few miles you will never have to worry about dumping again. The bad, if it's a fresh water tank, I'd always look for places to camp that had showers and places to wash your dishes.
Enjoy,
Paul Waddell
rideair is offline   Reply With Quote
Old 08-24-2014, 02:31 PM   #13
mimiandrews's Avatar
1966 22' Safari
Hilltop Lakes , Texas
Tank lash-up may be between frame rails
Most Airstream frames have two longitudinal frame members, not a single center rail. This tank appears to have been suspended between the frame rails. I agree that it's an unbelievable bit of poor engineering.
There are other reasons for a frame to be bad, so don't limit your checks to the area by the tank. Rust, rot, and other stuff are much more common.
Check the right-hand column of the Portal page for a link to volunteer Airstream inspectors who will help you evaluate a trailer for purchase. Also, there's a very detailed inspection checklist you should print and take with you.
Good luck!
Old 08-24-2014, 04:41 PM   #14
1966 17' Caravel
Again I don't think that what we see is the main frame but an additional support rail (added at a later time) I also do not think that the tank we see is original so we do need more pictures.
Cliff
Yes I said that! Or did I?
LP gas line compromised by equalizer hitch stabilizer bracket bolts bike2443 LP Gas, Piping, Tanks & Regulators 1 08-04-2014 07:49 PM
Advice on gaucho/jacknife frame frame & wall remodel chiefbrody General Interior Topics 0 01-30-2013 04:38 AM
Beatrice era frame experts if you please. Odd frame issue Kevin245 Repairing/Replacing Floor &/or Frame 5 08-25-2012 09:55 AM
Frame Repair or New Frame muddy_hollow Brakes & Brake Controllers 14 09-26-2006 05:55 PM
Window Frame Removal 64GT Windows & Screens 4 04-09-2002 12:40 PM
