Originally Posted by Jeremy J
I am replacing a rusted out section of the rear main C channel on our Overlander. I ordered some 5" C Channel from a supplier but didn't rea;lize that the frame was so thin. It looks like it's basically 1/8" thick but all I can find is 3/8". Anyone found any place online that I could order the correct C Channel or know a place in Austin that has it. I've called all over and haven't been able to find any.
I doubt you will find anything "off the shelf" that will match.
You might try calling a nearby fabrication/welding shop. Ask if they have the ability to bend/make a bent plate fabrication from heavy gauge metal.
I think 10, 11, or 12 gauge is about right.
check out this chart>
http://www.metaltrone.com/metalgauge-chart.pdf
