Old 05-31-2004, 01:19 PM   #1
till's Avatar
Lisle , Illinois
Images: 108
Found the problem....
Well I decided to cut a few holes to see what's what....
Tedd Ill
AIR#3788 TAC IL-10
No trailers...
till is offline   Reply With Quote
Old 05-31-2004, 01:22 PM   #2
till's Avatar
Lisle , Illinois
Images: 108
Sorry, that first one is the Wreck in it's new home.
here is another one of the break in the frame...
Tedd Ill
AIR#3788 TAC IL-10
No trailers...
Old 05-31-2004, 01:43 PM   #3
Images: 59
Tedd,
Looks like it broke right behind a crossmember. Do you think there was some damage from the cossmember weld?
Old 05-31-2004, 02:13 PM   #4
till's Avatar
Lisle , Illinois
Images: 108
The break is just behind the axles. It is between the cross members That is where the "rear end sag" starts on the street side. The crack or should I say split is in the furthest hole in the picture.....
Tedd Ill
AIR#3788 TAC IL-10
No trailers...
Old 05-31-2004, 03:16 PM   #5
53flyingcloud's Avatar
1984 29' Sovereign
Savannah , Missouri
What are your plans?
till,
Just curious..
This sounds like a huge project for a shell off frame restoration~
I'm just wondering..
Will be watching your progress..All the best to you~
ciao
53FC
WBCCI 5292 AIR 807
NEU #64
New England Unit
53flyingcloud is offline   Reply With Quote
Old 05-31-2004, 03:44 PM   #6
till's Avatar
Lisle , Illinois
Images: 108
53FC,
That is the plan, remove the shell and strip the floor. Since I did not find any rust damage, I'm sure I can weld / patch any damge that is in the frame.
Tedd Ill
AIR#3788 TAC IL-10
No trailers...
Old 05-31-2004, 04:04 PM   #7
Images: 59
Tedd,
I assumed the blistered line about 1" to the right of the crack was the shadow of a crossmember weld on the other side. Is that just a rust line, like the diagonal one further to the right?
Old 05-31-2004, 05:01 PM   #8
greg176's Avatar
Gabriola Island , British Columbia
What I see in the pictures is a crossmember and not the main frame rail.It requires attention but is most probably not the cause of your rear end sag but the result of it.You'll have to dig further.
greg176 is offline   Reply With Quote
Old 05-31-2004, 06:20 PM   #9
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
I do not agree. Look at the thickness of the steel.
Tedd's Airstream is the same year as mine, only two feet longer. His picture is most likely showing us where the wiring enters the interior just aft of the rear axle to connect to the battery. For perspective, I have attached a jpeg of what I think is the "top" side of what Tedd is sharing with us. The black sheathing near the center of the picture is a continuation of what is underneath. The forefront shows the heating duct to the bath.
He has a situation. But, with the shell off, it appears to be a simple weld job.
Tom
Old 05-31-2004, 06:29 PM   #10
greg176's Avatar
TC
Yes it looks like I put my foot in it again.On my '61 the frame rails are made of heavy 4" "C" channel and the cross members are folded .080 steel sheet.Those photos look like steel sheet not heavy channel.I looked at some more photos of newer units and sure enough that's all the had for main frame.No wonder they fail.For a few photos of my new frame go to
http://www.airforums.com/forum...t=frame+repair
It is also worth noting that the heavy channel is also reinforced in area of axles.
Old 05-31-2004, 07:39 PM   #11
till's Avatar
Lisle , Illinois
Images: 108
TC is right on about the location. I should add that I have jacked up the rear frame section to see if the floor/side bulge straightened out any. They have.
Mark,
That blister may be an outriger welded to the frame rail. I will see more once I get the shell off and the floor out. I'm thrilled to find that most of the frame paint is in great shape. The insulation is dry and clean too.
Tedd Ill
AIR#3788 TAC IL-10
No trailers...
Old 05-31-2004, 08:06 PM   #12
greg176's Avatar
Here's a pic of the new "61 frame in same location, at end of reinforcement plate.There is a piece if frame channel on top for illustration of size.
Univolt common problem 71tradewind 1970-79 Tradewind 21 06-08-2011 11:36 PM
my '77 land yacht w/o brakes wayne.yl Brakes & Brake Controllers 20 12-26-2003 06:55 PM
Argosy water fill problem mcneon Argosy Motorhomes 1 10-09-2003 05:30 AM
B190 Coach power problem Luckydog Sprinter and B-van Forum 21 11-12-2002 12:59 PM
Electrical problem resolved davidz71 Electrical - Systems, Generators, Batteries & Solar 5 08-12-2002 08:21 PM
