Old 07-11-2004, 12:44 PM   #1
JeepinAudiophile's Avatar
1968 24' Tradewind
Fort Myers , Florida
Images: 66
Send a message via AIM to JeepinAudiophile Send a message via Yahoo to JeepinAudiophile
foam under plywood flooring?
I have not heard any mention of foam under the plywood flooring in am going to replace... i just got finished with the inner skin, and both inner-shells. I was taking a look at a soft spot on the floor and started picking at it. There appears to be some kind of foam under the plywood. It may only be where i happened to poke, but i do not know as of yet. I anyone knows what i am talking about i would appreciate it if someone would chime in and let me know what it is, and if i'm going to need to replace the mystery layer of foam as well as the plywood. Thanks for all the info i'm sure to get, Chad.
Tow Rig: 2005 GMC Sierra Denali AWD, 6.0L HO- LOTS OF UPGRADES to help Towing (and Fun)
Trailer: 1968 Tradewind 24', Land Yacht trim (Shell-Off Rebuild and upgrades)
***Missing from my life***
WBCCI # 13657
++Take a look at my restoration photo album++
http://picasaweb.google.com/ChadsAirstream
JeepinAudiophile is offline   Reply With Quote
Old 07-11-2004, 01:00 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
On some trailers, there appears to be a layer of insulation under the floor, and a layer of aluminum skin just under that. It is usually in the front of the trailerm centered. It is for when the belly pan is cut open in that location for placement of the spare tire. Not all trailers have it, and I haven't seen the insulation anywhere but in that spot.
Old 07-11-2004, 01:02 PM   #3
1968 24' Tradewind
Images: 66
Thank You for the quick reply, looks like that is one question answered...now i guess it's time to get back to working on it. Thanks again, happy trails- Chad
WBCCI # 13657
Old 07-12-2004, 08:44 PM   #4
1968 24' Tradewind
Images: 66
Just to clear it up... It ended up being that spray-in foam insulation stuff. At some point it was sprayed up onto the bottom of the plywood. I'm not sure if this is some thing done at the factory, but it also had some panel work before i received it. Maybe the belly was dropped then and sprayed to prevent any more water damage on the plywood?
WBCCI # 13657
Marmoleum Flooring J-n-A Our Community 34 03-10-2013 11:13 PM
Looking for 5mm or 3/16" plywood fitzjo1 Cabinets, Counter Tops & Furnishings 6 03-10-2004 08:54 PM
Need help removing plywood floor section brentleew Repairing/Replacing Floor &/or Frame 49 02-16-2004 04:46 AM
Flooring Fun-Lovin Floor Finishes 8 09-09-2003 11:15 AM
Replacing the flooring - 61 Bambi 61BambiCanada Upholstery, Blinds, Walls & Interior Finishes 2 06-10-2002 07:59 AM
