Old 04-24-2017, 10:32 PM   #1
ALUMINUM OBSSESSION
1993 34' Limited
Hamilton , Ontario
Flooring replacement
Hi fellow airstreamers!! I have pulled part of rear flooring out of my 34 airstream classic. (rear section)
I notice the OSB wood was pushed into aluminum channel in side walls at the bottom. etc.
How can I remove the old OSB wood in the channel?
I want to do a proper job!!!
I would really appreciate you feed back!!!
Bill
william Haym is offline   Reply With Quote
Old 04-25-2017, 04:47 PM   #2
sgschwend's Avatar
1986 25' Sovereign
2008 F350, 6.4L diesel , Oak Harbor, WA
Images: 13
You take it out a chip at a time, hammer, chisel, pliers, and other hand tools.
s
sgschwend is offline   Reply With Quote
Old 04-25-2017, 05:46 PM   #3
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
The vibrating "multi-tool" type tools work well. I have one from Harbor Freight that I have used countless hours. It was the best thing I found to get the old rotten, in my case plywood, flooring out of the c-channel. Buy good blades, they last much longer than the one that came with it.
http://www.harborfreight.com/power-t...ool-62279.html
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
Old 04-25-2017, 06:04 PM   #4
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Hi Bill, I have one of those sonic powered vibortory tools, and it was very useful in my project this winter replacing a soft OSB section of floor in the rear of our 86 34' Airstream. I call it my "plunge cut" tool.
The bad spot was under the street side twin bed. I found it more difficult to get the new floor inserted in the channel that getting the rotted stuff out. I had to sand to get it to fit tight. I drove it all the way in with a hammer. I replaced the bad section of flooring in three sections, using the frame rail and cross members for support and anchor points.
My soft spot was due to a leaky taillight fixture, now fixed. Always something.
David
Name:	1612 Floor Repair Rot Hole (Small).JPG
ID:	284152   Click image for larger version
Name:	1612 Floor Repair Out (Small).JPG
Name:	1612 Floor Repaired 1 (Small).JPG
Old 04-25-2017, 10:03 PM   #5
ALUMINUM OBSSESSION
1993 34' Limited
Hamilton , Ontario
Thanks Bruce for your help!!!
I will try this tool.
Bill
Old 04-26-2017, 05:36 PM   #6
ALUMINUM OBSSESSION
1993 34' Limited
Hamilton , Ontario
Hi Bruce
That vibrating worked excellent.
Hopefully some day I can return the favour!!!
Flooring Replacement & Toilet Flange DEITZ645 Sinks, Showers & Toilets 10 03-29-2012 12:16 PM
Flooring replacement and removing under panels AArchitect Repairing/Replacing Floor &/or Frame 8 11-13-2010 03:18 PM
Side-to-Side Flooring Replacement in Classic MH Eddy Repairing/Replacing Floor &/or Frame 12 11-03-2006 01:08 PM
partial removal & replacement of sub flooring B Stover General Interior Topics 6 08-12-2005 03:32 PM
