Old 03-31-2015, 05:00 PM   #1
charleston , West Virginia
flooring repairs too!
I have ripped up rotted subfloor in the front half (and now bathroom) of my 77 overlander. Pardon the rookie question, but how critical is it that the flooring is up in the channel along the bottom of the wall? I didn't cut my front piece perfectly and it isn't up under there that good. Also I had to cut the original bolts that were used to hold the subfloor to the frame and I planned to just use self tapping screws to reattach the new subfloor to the frame? Is that ok to do that?
vcsnover is offline   Reply With Quote
Old 04-01-2015, 07:51 AM   #2
aquinob's Avatar
Portsmouth , Virginia
It could be very critical. The upper aluminum structure ties to the steel frame through the plywood subfloor that sits underneath that c channel. The c channel has to be bolted through to the frame as well as bolted into the plywood to form a rigid box otherwise it will flex and you will see interior rivets start to pop.
Ongoing adventures at:
https://1973overlander.blogspot.com/
aquinob is offline   Reply With Quote
Old 04-07-2015, 04:54 PM   #3
1988 34' Excella
Stanardsville , Virginia
Thanks for that info, I'm a newbie and that really helps plan what needs to be attempted first. Do you know where I can find a diagram of the frame with dimension data on an older Airstream?
madpiper is offline   Reply With Quote
Hitch Ball Too High, or Too Low SteveH Hitches, Couplers & Balls 30 10-21-2014 05:10 PM
Too humid too sleep even with A/C on WineStream Dehumidifiers & Ozone Generators 27 09-28-2009 08:46 PM
safety chains: too long/not too long? kfrere Hitches, Couplers & Balls 16 04-27-2009 10:14 AM
Trailer too Large? TV too small? pixiehat Tow Vehicles 45 03-13-2009 09:36 AM
How much is too much, or too little - 1962 Globetrotter? gduffydc 1960 - 1964 Globetrotter 3 01-07-2009 02:39 PM
