Old 07-18-2015, 01:16 AM   #1
1954 25' Cruiser
Cody , Wyoming
Flooring laid first?
We are planning on laying LVT plank floating floor in our 54 cruiser. She is empty and was wondering if we can lay the floor now and add cabinets on top later? Will cabinets interfere with the expanding and contracting?
TIN!!
jtfink is offline   Reply With Quote
Old 07-18-2015, 04:41 AM   #2
SteveH's Avatar
Common Sense , Texas
TIN!!
Can't tell you about that type of flooring, but that's what the factory does with vinyl and carpet.
Regards,
Steve
Old 07-18-2015, 06:35 AM   #3
CBWELL's Avatar
1994 34' Excella
Warren , Manitoba
Any time that you anchor through the floating floor you are inhibiting the movement. If you anchor the cabinets or anything else to the floor, through the planks, the only way is to use an enlarged hole for the fastener and the item can not be anchoredtightly, or movement will be inhibited. Check with your flooring supplier. They are the ones giving the warranty. Chris
ACI #7394
2012 GMC 2500 HD Duramax Denali
1994 Excella 34'
1987 Limited 34', 1976 31', 1976 Argosy 22' Gone to new homes
Hensley Hitch
CBWELL is offline   Reply With Quote
Old 07-18-2015, 07:20 AM   #4
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
I wouldn't. Secure cabinetry. Eliminate potential damage to floor during work. Install last.
Peace and Blessings..
Channing
WBCCI# 30676
Old 07-18-2015, 07:36 AM   #5
KJRitchie's Avatar
2008 25' Classic
Full Time , Texas
Seal the floor to prevent water from soaking in if/when you get a leak from a window, lay the cabinets then install a floating floor. AS lays the floor then installs the cabinets (All RV manufacturers seem to do this). My vinyl floor is bulging now in several places due to temperature extremes between seasons.
Kelvin
Old 07-18-2015, 08:43 AM   #6
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
We did flooring first per recommendation from a very well known professional AS restorer at Vintage Academy. Our cabinetry is attached to the walls, and floats on the floors. Four years and extreme temp changes, no problems.
The biggest down side for us is it cost more for flooring because we used more of it. The advantage was the ease of laying it. Very little "fitting".
Our flooring is a floating cork product.
Kay
Old 07-18-2015, 10:18 AM   #7
1954 25' Cruiser
Cody , Wyoming
What type of flooring did you put in?
Old 07-18-2015, 11:21 AM   #8
Minno's Avatar
1972 31' Sovereign
Lisbon Cork from Lumber Liquidators. They are 1 x 3 foot tiles that click-lock together.
Chris
Murder Charges Finally Laid - Missing Motorhome Couple Fly at Night Off Topic Forum 8 04-24-2012 11:09 PM
My first vintage airstream and first problem m00d Our Community 5 08-23-2005 03:56 PM
First Big Trip, First Time Float Tubers :eek: Rhodie On The Road... 14 08-11-2005 02:18 AM
Floor is laid markdoane Repairing/Replacing Floor &/or Frame 3 08-05-2004 09:27 PM
