Old 02-15-2007, 08:59 AM   #1
1972 27' Overlander
cass , Texas
Smile Flooring around toilet
We have a 1972 Overlander. We are starting to put a new vinyl floor in it. Would it be better to tile around the toilet, or remove it? Is their any other tips or suggestions, or secrets that might help? Thank you
krazeekalvin is offline   Reply With Quote
Old 02-15-2007, 09:21 AM   #2
BIGED52's Avatar
1967 22' Safari
MILAN , Illinois
Your choice
You can do it either way just be sure to use a pattern cut from poster board or cardboard to get an accurate representation of the floor area to be cut onto the vinyl tile or roll flooring. If you remove the stool and riser then just cut flooring around black tank flange. Layout for all cuts around edges and commode are essential for a good looking finished floor. Seal around stool areas and wall edges to keep moisture from getting to sub-floor. I would use a latex/butyl sealant rather than silicone around the wall edges as it will stick better to the aluminum and be easier to remove in the future. You may want to consider using Sikaflex221 as it would be gray rather than white. Ed
1967 Safari Twin "Landshark" w/International trim package
1999 GMC Sierra 1500 SLT
FORUMS MEMBER SINCE 12/16/2004AIR#7110
"My tire was thumping, I thought it was flat. When I looked at the tire, I noticed your CAT!" Burma Shave
BIGED52 is offline   Reply With Quote
Old 02-15-2007, 09:34 AM   #3
1972 27' Overlander
cass , Texas
Is is hard to remove the toilet? I am a first timer. Thanks
Old 02-15-2007, 09:39 AM   #4
Fyrzowt's Avatar
West of Fort Worth , Texas
Images: 8
I'm about to find out! I have a new one ordered.
I have removed one on an SOB, there were 2 hold-down studs/nuts. One of them was awkward and I had to use a special wrench to reach it. (Chevy distributer wrench)
I believe that the 2 bolt arrangement is pretty standard, and how much room your model has around the toilet will affect access.
Dave
Fyrzowt is offline   Reply With Quote
Old 02-15-2007, 09:43 AM   #5
BIGED52's Avatar
1967 22' Safari
MILAN , Illinois
Toilet removal
Just remember to take pics before and after so you can brag! Also post them here so we can see what you did! Ed
Old 02-15-2007, 09:49 AM   #6
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Riverhead , New York
Simple two bollts, the bolts are secired to the ring which is screwed into the tank.
Remove two nuts off the bolts lift toilet.
Put the floor in tight to that ring which should be screwed to the floor.
A bead of regular siliconee in a color to match around, done.
Now onto the next job.
'77 Sovereign Intl 31' CB
Old 02-15-2007, 12:21 PM   #7
1978 31' Excella 500
Goose Creek , South Carolina
ditto,
Remove the toilet, its easy faster and cleaner.
Holzarbeiter is offline   Reply With Quote
Old 02-15-2007, 04:06 PM   #8
balrgn's Avatar
1974 27' Overlander
1954 26' Romany Cruiser
1960 26' Overlander
Rockingham County , New Hampshire
Images: 74
Send a message via AIM to balrgn Send a message via Yahoo to balrgn
Just did one in our '73
Overlander_Interior
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'54 Cruiser (Bogart)
'60 Overlander (Hoagy)
WBCCI 1754 - AIR # 6281
www.balrgn.com
balrgn is offline   Reply With Quote
Toilet Replacement 3Ms75Argosy Sinks, Showers & Toilets 22 02-18-2007 08:51 PM
Rear toilet platform rotten, now what?? MontanaArgy Cabinets, Counter Tops & Furnishings 9 08-14-2005 07:46 AM
Toilet Overflow bentguy Sinks, Showers & Toilets 4 07-09-2004 04:07 PM
toilet doesn't hold water.... Chuck Sinks, Showers & Toilets 12 10-08-2002 11:03 AM
Replacing the flooring - 61 Bambi 61BambiCanada Upholstery, Blinds, Walls & Interior Finishes 2 06-10-2002 08:59 AM
