Old 05-26-2016, 11:58 PM   #1
dcole's Avatar
1964 22' Safari
Portland , Oregon
Floor to frame bolt holes
I just pulled off the shell on my 64 Safari and getting ready to put on a new floor. I noticed the original frame bolt holes are oversize. Are folks reusing these holes or drilling new ones?
Here is the system I was using: pilot drilling (1/8" bit) the new plywood from underneath through the center of each original hole. Then using a forstner bit from the top to counter sink the elevator bolt heads, finally finish drilling with a 1/4" bit. I messed up that piece of plywood, so I'm starting over. I'm wondering if I'm over thinking this one and should just drill new holes from the top. Thoughts?
Name:	2016-05-26 20.35.20.jpg
dcole is offline   Reply With Quote
Old 05-27-2016, 03:35 AM   #2
Images: 59
I can't even remember which method I used.
As soon as you place the sheets on the frame and try a few you'll discover which is easier. Its an awful lot of crawling around on your back if you try to reuse the original holes.
Frame Mounted Eye Bolt for the Dog/Security dsaxon22 The Pet Forum 3 03-04-2014 11:31 AM
Plugging holes on the A frame Tino643 General Repair Forum 2 04-10-2013 07:37 PM
New toilet holes don't match old holes RichHog Sinks, Showers & Toilets 8 03-15-2009 06:36 PM
Stripped lug bolt holes chris's 67 Wheels, Hubs & Bearings 3 03-30-2008 05:27 PM
Screw holes in Tradewind floor yochanan Repairing/Replacing Floor &/or Frame 1 01-21-2006 11:50 PM
