Old 10-11-2002, 09:17 AM   #1
jeanarlene
jeanarlene
Profile:  1971 23' Safari
Lake Ann , Michigan
Cool Floor support question
Well, Airabelle has recovered from being shot --as related on this website earlier--someone shot out her front right wing window and culprit still hasn't been caught. I've tracked down a clear glass replacement due to arrive in a month. Meanwhile I've secured the area with heavy vinyl. But, rain apparently penetrated this area before the shotgun blast. The wood subfloor is weakened in some places and pulled away in a couple spots, around 2 inches in diameter. Probably I should have put penetrating epoxy in those areas. Instead I relied on flooring workman to reinforce those areas when he came to lay tile yesterday. He used Ardex and lots of adhesive when he laid the vinyl tile. We both knew the proper thing to have done is replace the floor. That would involved lots of $, lifting the shell, etc. so I made the decision to proceed with the tile and put on my truth blinders (again) and hope for the best. Now I have to decide which would the floor more easily support in that weakened area--a couch or a dinette? Does anyone have a clue?
Jeanarlene
jeanarlene is offline   Reply With Quote
Old 10-11-2002, 10:26 AM   #2
74Argosy24MH
Profile:  LOST , Hawaii
Use masking tape on the floor to lay out where both of them would go. You know where the weak areas are, decide which layout would have the most traffic and most load (from the couch or dinette) on the weak areas. Don't forget storage under each, although you could reinforce above the floor with a piece of plywood.
John
74Argosy24MH is offline   Reply With Quote
Tri Axle Question HowieE Axles 30 10-27-2004 08:44 PM
Oil in Generator Question flyfisher Generators & Solar Power 4 12-29-2003 03:50 PM
Question regarding GVWR joshua32064 Tow Vehicles 6 10-19-2003 07:57 PM
Rust Question drober05 Airstream Motorhome Forums 6 10-05-2003 02:09 PM
Loaded question: avg miles per set of brake pads John Brakes & Brake Controllers 2 12-12-2002 05:01 AM
