Old 06-29-2008, 04:59 AM   #1
Floor rot in small spot!
Discovered a small soft spot from water leak. Spot is on floor under arm of gaucho. I know there is a two-part product I can mix to smear on the floor to "repair" this spot but cannot recall name of it. Any other suggestions. Don't know how we missed seeing this little spot until the chipboard flooring actually became soft.
Excella 1000 29' 1988
Anniedog is offline   Reply With Quote
Old 06-29-2008, 06:01 AM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
What you are looking for is called "Rot Doctor". It is also available in other brand names.
Old 06-29-2008, 07:35 AM   #3
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
also called
I used "Get Rot" which I bought at West Marine.
Old 06-29-2008, 12:31 PM   #4
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
Is it rot or just delaminated? If it is just delaminated. I have used a cure that a chemist friend came up with, that is, two part five minute epoxy mixed with denatured alcohol. The mixture is very thin and watery, It soaks into the wood, then the alcohol evaporates, then the epoxy goes off. Next day, sand and finish.
The result is great.
If it is dry rot, you should use "Get Rot" or replace the bad area. Dry rot will keep on spreading.
Help! need info on weak spot in front floor. Venpetra Repairing/Replacing Floor &/or Frame 3 09-21-2007 06:57 PM
77 Argosy floor rot kontiki Repairing/Replacing Floor &/or Frame 4 10-21-2006 06:09 PM
Low spot in floor... Torii Repairing/Replacing Floor &/or Frame 3 03-21-2006 04:33 PM
repairing floor rot danesh Repairing/Replacing Floor &/or Frame 18 02-03-2004 09:34 PM
Floor Rot mmeburges1 Repairing/Replacing Floor &/or Frame 3 01-10-2004 06:21 PM
