11-28-2017, 05:15 PM
2007 31' Classic
Gulf Breeze
Floor rot
Today begins my bedroom floor rot repair. So far I have removed the bed platform and the diamond plate from the storage locker. There is substantial rotten sub flooring extending about four feet into the trailer. The discouraging thing is that the floor is still soaked...even after I have sealed the “bumper joint” plus all windows, lights, etc. when I removed the diamond plate from the storage compartment there was moisture on the bottom of the plate. We have not had any rain for a month and I wonder if this moisture could be condensation.
Now I need to remove the closets. Any suggestions? I don’t see any fasteners holding them in.
11-29-2017, 01:22 PM
2007 31' Classic
Gulf Breeze
Many thanks to Vinnie at Vinnies Northbay Airstream for some phone coaching. I got the side closets removed and now ready to begin demo of the rotted sub floor. What a mess but I can take my time and work a few hours each day.
11-29-2017, 01:24 PM
2005 30' Safari
Montgomery
Thanks for following up! I didn't have any advice to offer, but our coach looked much like that (2005 30' Safari) in the front and in the back--though the back needed the most new subfloor. Good luck and keep up posted! Take lots of pics of the process!
11-30-2017, 02:58 PM
2007 31' Classic
Gulf Breeze
11-30-2017, 03:08 PM
2007 31' Classic
Gulf Breeze
Two things that jumped out at me today. There is no insulation in the belly pan...just a thin sheet of bubble wrap. The belly pan is totally clean. I have read of pans that were full of rodent droppings, dirt, leaves, etc. but mine is clean. Thankful for small things.
12-01-2017, 03:31 PM
2007 31' Classic
Gulf Breeze
Day three and good progress. All bad floor is removed and I have just 3 more feet of C Channel to clean. For those attempting this project I found that a Dremmel with a wood burr works really well to get deep into the channel.
I don’t know why my photos turn sideways.
12-01-2017, 04:41 PM
Mercer Island
I had that bubble wrap insulation under my floor too. It was full of water - actually was a part of the problem. There are other threads here where folks replaced them with 'hard' foam insulation boards (i just removed the old and didn't replace).
12-01-2017, 05:28 PM
1967 17' Caravel
Oak Creek
Originally Posted by trumpetguy
Day three and good progress. All bad floor is removed and I have just 3 more feet of C Channel to clean. For those attempting this project I found that a Dremmel with a wood burr works really well to get deep into the channel. Attachment 300135
If you crop them just a bit they will be right when you post.
12-02-2017, 07:21 AM
2007 31' Classic
Gulf Breeze
I noticed the same thing. Water in the bubble wrap. I do not plat on replacing it. I will lay some pink stuff insulation in the belly pan though. Should help with temperature.
12-02-2017, 07:23 AM
2007 31' Classic
Gulf Breeze
Did you have to install the new sub floor in sections? I can’t see how to avoid it because the floor needs to be wider than the interior skin so it can fit into the C Channel.
12-02-2017, 09:34 AM
2008 27' International FB
Petaluma
Floor woes
Nice work so far. My wet floor tale starts about half way down page 18
http://www.airforums.com/forums/f396...-56099-18.html
I have some shots of how I replaced the insulation. I was lucky that my wood was strong enough to save with epoxy.
Keep up the good work, steady as she goes. Glad you found Vinnie he is the voice of reason and gladly delivers guidance backed by experience.
12-02-2017, 10:37 AM
2009 27' FB Flying Cloud
1982 31' International
1991 35' Airstream 350
Jay
, Oklahoma
I would suggest against placing fiberglass insulation in the belly pan.
Airstream quit this several years ago in favor of the bubble wrap
The fiberglass bats hold water worse than the bubble wrap and are the cause of the rotted frames on the older trailers.
Regards,
JD
Jeff & Cindy
'09 27FB Flying Cloud;'82 31 International
'91 350 LE MH; '21 Interstate 24GT
12-02-2017, 01:03 PM
2007 31' Classic
Gulf Breeze
JD. Thanks for that tip. Vinnie did say that if Airstream had just made a small slit in the bubble wrap they would have avoided a lot of problems. I guess that would allow moisture to wick out into the belly pan.
12-02-2017, 01:10 PM
2007 31' Classic
Gulf Breeze
Wow. The C Channel is clean. What a back breaker. The little Dremmel with a cutting bit proved to be the absolute best tool. I cut the old flooring off even with the wall then used the Dremmel to make a plunge cut. Pressure up and Down eventually cut through the plywood from top to bottom. I made many cuts about two inches apart then used a screwdriver to pry the bit out. Tedious but effective.
Question. Is it best to use tongue and groove flooring or will standard 5/8 sheeting suffice. The floor where I stopped removing is a tongue piece which I can cut off the tongue or just use a square piece and fill the gap with Bondo.
12-02-2017, 01:16 PM
2007 31' Classic
Gulf Breeze
Ready for flooring.
12-02-2017, 01:20 PM
2018 28' International
Renton
Wow, this scares the heck out of me. We picked up a 2009 27FB this fall. Now that its started raining I need to get a moisture meter and start checking the floor under our dinette (in the rear).
Walt
2018 28 International Serenity
2013 F150 Ecoboost
12-02-2017, 02:44 PM
2002 30' Classic
Ocala
Did you find the source of the leak? Doing all that work and not fixing leak you'll have the same problem again.
12-03-2017, 07:11 AM
2007 31' Classic
Gulf Breeze
Floor rot
I believe the source of the leak was where the rear bumper meets the trailer. This is a common problem with my unit. Airstream sent me a technical bulletin on how to correct the problem which envolved removing the belt molding and belly band, then caulking with Vulkem. I have also sealed the windows, exterior lights, etc. My next step is to place some light blue paper towels along the rear walls and douse the trailer with water. The location of the rotted wood makes it clear where the intrusion was...right under the storage locker which is where the lack of caulking has been problematic on these units.
If you own a 2007 be sure to inspect the area described.
12-03-2017, 08:20 AM
1967 17' Caravel
Oak Creek
The sides will push out to do the center sections & the ends will slide in under the channel .
Don't split your sheets down the middle or it weakens the structure & strength of the monocoque design.
It takes a bit of finagleing to get them in but they will go.
I did mine by myself. I'm tall so I have a large wing span to pick up the sheets. :-)
Take your window screens out of the side windows & open the side windows. I saw where it would be really easy to wreck either of these.
Hope this helps more than hinders. ;-)
12-03-2017, 08:23 AM
1967 17' Caravel
Oak Creek
This was in reply to Trumpetguys question
