Old 06-03-2015, 01:50 PM   #1
minneapolis , Minnesota
floor rot
I have a 2005 Safari and I think I'm seeing the beginning of floor rot in the form of light pinkish/purple stains with very dark soft spots here and there in the vinyl flooring. I suspect it is caused by a leaky kitchen faucet or a leaky water tank. My question is: has anyone with a Safari 25 had their floor replaced by the pros and how much did it cost? Also I'm trying to figure out what kind of leak I have in my water tank. There are two holes in the bottom of the tank that were manufactured in and they drip water, one fast, one slow. When I put my finger on the slow drip hole nothing happens, I remove my finger and it resumes the slow drip. When I stop up the fast drip hole and then remove my finger there is a solid stream for a little while and then it goes back to the fast drip. I'm attaching some photos of the drip holes in which you can see deposits around them. Has anyone seen this type of leak before?
ID:	239927   Click image for larger version
ID:	239929   Click image for larger version
sls25 is offline   Reply With Quote
how much rot is too much rot? adwriter73 Repairing/Replacing Floor &/or Frame 56 02-28-2010 11:05 PM
Hypothetical....How Do I Inspect a Used trailer for Floor Rot prior to making an Offe route66 Repairing/Replacing Floor &/or Frame 13 02-07-2006 08:18 PM
To rot or not to rot. Charming Wino Repairing/Replacing Floor &/or Frame 15 03-01-2004 10:39 PM
repairing floor rot danesh Repairing/Replacing Floor &/or Frame 18 02-03-2004 09:34 PM
Floor Rot mmeburges1 Repairing/Replacing Floor &/or Frame 3 01-10-2004 06:21 PM
