Old 03-16-2007, 11:53 AM   #15
ZoominC6's Avatar
2004 30' Classic Slideout
Colleyville , Texas
Advantec
If it's all about the money, go with plywood, marine grade or exterior grade. If it's about durability and the lifetime of the floor, consider this; visit your local lumberyard and inquire about ADVANTEC. I believe that I have the spelling correct, anyhow, they will know what to tell you. This 'plywood' comes with a guarantee that you will need to ask about. I've used it in construction and tested it in all kinds of weather over a yearlong project. It never changes in thickness or character. We utilized it from that point forward in subfloors that would be exposed to the elements for long periods until the roof was 'dried in'. The material is a little heavier than plywood and is costly; however, darned good insurance for the long haul. Good luck.
HAPPY TRAILS
In dog years, I'm dead!
ZoominC6 is offline   Reply With Quote
Old 03-16-2007, 12:17 PM   #16
Images: 59
Originally Posted by ZoominC6
. . consider this; visit your local lumberyard and inquire about ADVANTEC. I believe that I have the spelling correct, anyhow, they will know what to tell you.
The spelling is Advantech, manufactured by Huber.
I used exterior plywood on my floor, but if i was doing it again I would use Advantech. The specs are just to good to ignore.
markdoane is online now   Reply With Quote
Old 03-16-2007, 12:27 PM   #17
ZoominC6's Avatar
Colleyville , Texas
Thanks for 'spellchecking' me Mark! ;-) and for confirming my thoughts about the product. Modern technology is great, even if we do pay more for it at times.
Old 03-16-2007, 06:22 PM   #18
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Riverhead , New York
maybe 10-12lbs, the benefits out weight that many times over.
'77 Sovereign Intl 31' CB
Old 03-16-2007, 09:35 PM   #19
Hillgenbergonlocation
Hillgenberg's Avatar
1986 32' Excella
Santa Rosa Beach , Florida
Send a message via Yahoo to Hillgenberg
I like your idea of using fiberglass cloth and the resin. I have a small area I need to repair and had no idea how to handle the situation til I read your article.
Hillgenberg is offline   Reply With Quote
Old 03-17-2007, 11:03 AM   #20
Ken J's Avatar
1956 22' Flying Cloud
Durango , Colorado
Images: 14
The Airstream floor is 5/8 - however the tile on top of the floor (in which the shell sets on) is 1/8 - so 5/8 + 1/8 = 6/8 or 3/4. This is a calculation I missed when I did my floor - I saw the plywood was 5/8 so that is what I used - I wished I had used the 3/4 - oh well - the 5/8 is working well, the tile on top probably does not add any structure anyway and is just filler.
Ken J.
1956 Flying Cloud
Founder :
Four Corners Unit
Albuquerque National Balloon Fiesta
Rally
Vintage Trailer Academy - Formerly the original
restoration rally
Ken J is offline   Reply With Quote
Old 03-24-2007, 01:07 AM   #21
cuyeda's Avatar
Long Beach , California
After a discussion with a friend, I was thinking of using a 1/2" sub-floor plywood underlayment, then a 1/4" over the top for additional strength. Would a straight 3/4" be better?
Any thoughts about coating the plywood with a good primer (surface + edges) before installation? This should help slow any moisture seepage if any.
Is there a treated plywood sheating that helps resist termintes etc...? I will have to look into the Advantech stuff.
At Home Depot or Lowes, there does not seem to be 1/2" plywood.
cuyeda is offline   Reply With Quote
Old 03-24-2007, 06:42 AM   #22
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
3/4 is stronger than 1/2+1/4, because the 3/4 is one set of plys acting together as a total unit.
At the lumber yard Lowes HD you get something that is close to the thickness as you can they are playing games with 32's of an inch as a price game.
Old 03-24-2007, 10:21 AM   #23
Janets Husband's Avatar
1977 Argosy Minuet 6.0 Metre
1964 26' Overlander
1977 25' Tradewind
Eastern , Washington
Europly
I am thinking that a stiff floor is what I want. I am in the middle of a frame off and I was thinking of using 'Europly' it is much stiffer than standard plywood due to the number of layers in the sheet. It is like Baltic Birch but is available in 4' x 8' sheets and is FSC Formaldehyde Free for those who care.
A 1/2" sheet is 9 ply and 3/4" is 15 ply. The prices I have found is $85.00 for 1/2" and $91.00 for 3/4". 24 foot trailer will take 5 sheets. I was planning on pre-treating it with some type of water repellent, and I'm trying to figure out what I'll use.
Peace
Gary
Janets Husband is offline   Reply With Quote
Old 03-24-2007, 10:44 AM   #24
Ken J's Avatar
Durango , Colorado
Images: 14
Gary
Is this on the Argosy you are doing a frame off?
Anyway I coated my edges with epoxy and then sealed the floor with varathane. You have to be careful when using wood treatment in that it won't gas you out of the trailer....stuff should be made for indoor use.
Ken J
1956 Flying Cloud
Founder :
Four Corners Unit
Rally
restoration rally
Old 03-24-2007, 10:49 AM   #25
1964 26' Overlander
1977 25' Tradewind
Yep, it is our 1977 24' rear door, number 60 of 60 made. The floor really is a pile of mush. It appears the 1/2" plywood originally used fractures internally and it loses its stiffness. No rot, just flabby. Thanks Ken, I'll look into the interior grade water proofing.
Peace
Gary
Old 03-24-2007, 12:58 PM   #26
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Gary, I think Argosy trailers got 1/2" floors to save weight. Have you considered putting in the thicker flooring, like an Airstream of the same era would have had?
Old 03-24-2007, 08:48 PM   #27
Ken J's Avatar
Durango , Colorado
Images: 14
Oh ok - its not the one you have had all along - you must have snuck another on in on me - I don't know if you know this, but I did look at your original Argosy in Boisie when I was up there visiting Charle - even thought about buying it - its a very nice trailer.
Ken J.
1956 Flying Cloud
Founder :
Four Corners Unit
Rally
restoration rally
Old 03-24-2007, 10:13 PM   #28
1978 30' Argosy 30
tappan , New York
my 1978 argosy used 15/32 5 ply plywood and it had voids all over. bruce
bc057 is offline   Reply With Quote
Thickness of Window Glass/Lexan Pschoerrn Windows & Screens 15 10-28-2009 06:12 PM
Floor thickness??? BB 55 Bubble Repairing/Replacing Floor &/or Frame 1 03-18-2006 08:10 PM
Type and thickness of exterior skin? reece1107 Ribs, Skins & Rivets 6 02-19-2006 06:23 PM
1963 alloy thickness silvermoon Ribs, Skins & Rivets 4 10-25-2005 08:37 PM
vent cover repair.... Chuck Windows & Screens 10 11-13-2002 01:05 PM
