Prev Previous Post   Next Post Next
Old 12-23-2006, 07:35 PM   #1
Profile:  1962 22' Safari
austin , Texas
floor replacement, shell on or off
Hello,
I have just purchased a 62 safari- my first airstream. I need to replace the floor. From my research here I gather that I could replace the whole floor without taking off the shell. Is that accurate?
If so, I think that the front piece of plywood will slide in due to the radii on the leading edge. Should subsequent pieces be cut shy to be able to slide under both side walls? Could I cut them the proper length and flex it enough to fit under the walls? what if I double layer 5/16" ply? Or should I cut each one in half and have seams? I am disinclined th have seams in my floor. How far under the walls of my AS should the floor extend? All the way I suppose.
I look forward to hearing from some of you who have approached this problem alreaady.
Thank you,
Joe
joemccusker is offline   Reply With Quote
Removing the body shell and installing new floor completely - any one done this? williamhenshall Repairing/Replacing Floor &/or Frame 11 03-13-2006 12:21 PM
where belly meets floor meets shell JrnymnJay Repairing/Replacing Floor &/or Frame 6 01-09-2006 01:05 PM
Water Heater shell frame BobbyW Water Heaters, Filters & Pumps 0 04-29-2002 11:21 AM
