Old 08-05-2003, 06:40 PM   #1
srgntpepper's Avatar
Floor Replacement in 63 Safari
I am Replacing the floor in the front of the coach. I am am going to rmove the first section of the inner skin to acess the U channel. I am removing the entire skin because I don't think i can remove just the first few rivets and gain enough acess to the channel without bending the skin. My Question is do you have to remove any of the rivets on the exterior to get the channel free? Also if i drill out the interior rivets( pop looking type) with a 1/8" drill bit will i be able to use standard 1/8" alum. pop rivet witha large head to re secure the ineer skin? Also is the original flooring in this coach 5/8" thick? Thanks for any info Srgntpepper
srgntpepper is offline   Reply With Quote
Old 08-05-2003, 08:13 PM   #2
59toaster's Avatar
1959 22' Caravanner
Atlanta , Georgia
Images: 22
I'm going to be doing a simular repair on a Caravanner (same platform as your unit). From the information I have gathered from others that have done this repair your on the right track. There are a bunch of posts worth reading in the forums that cover this.
First thing you need to understand is the body is structural and a major part of the strenght of the unit. The frame is built light as a result and that's why these units weighed so much less then anything else in it's size. As a result it ies best, whenever possible, to replace a full width section of the floor back to the factory seam. The front 4 ft and rear 4 ft can be done without removing the body. The U channels changes shape at the first rib. once you get into that part of the floor it's usualy best to remove the body.
Now that old original tile is full of aspestos. Take the proper precautions.
The trick to replacing the front and rear ir to remove the rub stip the ends at the first rib. On the inside pull the lowered inner body pannels to access the lag bolts. Now on the toung end it gets a little trick because your going to be fighting the natural ballance of the trailer. On the rear you would strap the bumper to something heavy. Once you remove the rub strip and any rivits up to the first rib you lower the jack and this will cause the trailer to open like a clam. You might ahave to loosen the U channel lag bolts further back but not need to mess with the Bucked rivets past the rub strip. You only need about 2 inches and then you can slide the deck in or out.
On the front your going to need to take the tanks and anything above the frame off and that might include the jack. You might be able to work it in there with the Jack in place. Since your fighting the natural ballance your going to have to figure out how to hold the rear of the trailer down.
When doing the rear floor I have been told it only takes about 200lb worth of weight to get it to open up. You might be able to put some jack stand under the frame a couple feet in front of the tires (put a 4x4 that's full width of the unit under the trailer to put the stands under) and get the same effect by lowering the tounge jack or a floor jack under the tounge if you take the jpole jack off.
You want to try to remove the bad floor in one peice if possible so you can use it as a templet for the new peice.
InlandRV.com and www.airstreamdreams.com both sell Olympic rivets. These can be finished to look like the factory buck'd Rivet. The finish tool is EXPENSIVE but some people have had very good results using a concave qrinding stone on a dremel tool to finish the heads. Inland has recently put a drill bit kit together that has all the proper size drill bits for the rivets.
Good luck with it. I'm hoping to start taking our 59 apart tomorrow to start the same process.
1959 22' Caravanner
1988 R20 454 Suburban.
Atlanta, GA
59toaster is offline   Reply With Quote
Old 08-07-2003, 06:20 PM   #3
hey 59 toast thanks for the info things are going well just a few questions....by rub strip do you mean the narrow piece on the outside at the bottom that is below the main skin and the belly pan? Also to open the front up you have to put the 200 lbs on the rear? Thjanks fer any help
63 Safari Valliant Tankless WH??? srgntpepper Water Heaters, Filters & Pumps 6 11-06-2003 08:38 PM
63 Safari Dump Valve Questions srgntpepper Waste Systems, Tanks & Totes 1 09-10-2003 06:40 PM
'63 Safari srgntpepper 1960 - 1965 Safari 4 08-15-2003 02:37 PM
'63 Safari Water Pump? srgntpepper Water Heaters, Filters & Pumps 2 07-27-2003 08:22 PM
is glass for '63 Safari anything special ? oldvws Windows & Screens 3 11-25-2002 07:12 AM
