Old 07-17-2016, 12:13 PM   #1
1984 31' Excella
Cottage Grove , Minnesota
Floor replacement - c-channel bolt holes slipped 1in off frame holes
We're in the middle of removing our rotted floors in our 1984 Excella Airstream, and we've gotten to the section at the front, curbside door, and when I removed the piece of flooring under the door, the whole c-channel seemed to slip out away from the frame about an inch.
I've seen many pictures of people replacing their floors all at once instead of a section at a time, but I wasn't expecting this.
First, is this safe? Is my shell going to come crashing down on me if I try to take out more floor?
Second, how do I go about getting new floors in and getting this lined back up? I've seen people jack up the frame, and I'm assuming that's what I'll need to do next. Maybe after I relieve some of the pressure the sides and c-channel it'll pull back in?
Tim
Read more about our Airstream, Alice on our blog Rumble Strip Ramblings.
Instagram @rumblestripramblings
tshannon is offline   Reply With Quote
Old 07-20-2016, 07:45 PM   #2
AlbertaBound's Avatar
1975 Argosy 28
1975 Argosy 22
1978 Argosy Minuet 6.0 Metre
Camrose , Alberta
If it is just one out rigger it should not fall, but if it is a few of them it could. I would throw a ratchet strap on it and suck it back in. As for getting the plywood in you will need to lift the shell up again the thickness of the plywood.
AlbertaBound is offline   Reply With Quote
Old 07-21-2016, 04:07 AM   #3
Dingo Girl's Avatar
1967 17' Caravel
Cadillac , Michigan
My Caravel did the same thing.
I was able to pull it back in by hand. Then I cut pieces from the good wood from the old subfloor and stuck them between outriggers and c channel. Then used good clamps and clamped it all together.
Dingo Girl is offline   Reply With Quote
C channel/U channel replacement cole3444 Repairing/Replacing Floor &/or Frame 11 04-17-2019 05:20 PM
Shower Door has slipped SkippinOut Sinks, Showers & Toilets 31 04-11-2018 09:52 AM
Floor to frame bolt holes dcole Repairing/Replacing Floor &/or Frame 1 05-27-2016 03:35 AM
Slipped Off Folding Steps-Ouch! fastrob Steps 12 02-02-2009 09:30 AM
