Old 08-14-2014, 02:57 PM   #1
2001 23' Safari
Melancthon , Ontario
Floor replacement - aluminium
I have a 2001 Safari with a soft floor at the front. No doubt rotten but have not pulled up the vinyl for an inspection yet - all too scary. Having had an aluminium livestock trailer for our cattle business, I was wondering if anyone had replaced their Airstream wood floor with an aluminium one. The livestock trailer stood many, many years of manure and urine so I am sure such a floor would be even better than marine grade plywood as a replacement.
edpease is offline   Reply With Quote
Old 08-14-2014, 03:07 PM   #2
clancy_boy's Avatar
2003 22' International CCD
Kiln , Mississippi
Images: 8
It's not marine grade plywood under there but wafer board. Nothing special about it AT ALL.
Michael & Tina with Layla and Preston BZ
The family has grown.
2003 22' INTERNATIONAL CCD
Old 08-14-2014, 03:32 PM   #3
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
Some of the small Argosy trailers in the 70's had an all aluminum floor in them. I think the experiment was focused more on dropping weight than to making them rot-proof.
If you hunt around a little, you will find several threads about alternative subfloor materials. Everything from poly-board to various forms of aluminum to highly "finished" plywoods.
I doubt if you want to do a shell-off in order to replace all of your floor, especially if you have only one soft spot. Step one is to stop the leak. Step two is to fix the floor with a patch.
good luck!
Old 08-14-2014, 04:04 PM   #4
youngpeck's Avatar
1976 25' Caravanner
Salt Lake City , Utah
TimZog in Ogden, Utah has put an aluminum floor in his 1980 Caravelle. Here is the link:
http://www.airforums.com/forums/f379...ml#post1322655
For starters, post #243.
youngpeck is offline   Reply With Quote
Aluminium Grades 71airON Cleaning, Stripping & Polishing 8 07-15-2017 04:37 PM
Belly Pan Aluminium Streamsaver Belly Pans & Banana Wraps 5 09-08-2014 10:11 AM
Anybody used Zep floor finish on their aluminium body? marcosyh Clearcoat, Exterior Paint & Trim 2 10-29-2013 01:06 PM
WTB: '83 Excella HUBCAP 15" Aluminium 6 Beach rats 1981 - 1983 Excella 0 02-02-2009 06:25 PM
Styrene end caps for the aluminium bed extrusions chasgould Upholstery, Blinds, Walls & Interior Finishes 0 05-23-2004 05:23 PM
