Old 01-11-2006, 09:57 AM   #101
NorCal Bambi's Avatar
1963 16' Bambi
Yreka , California
Images: 21
Elevator bolts di-electric corrosion
Here are pictures showing similar technique used on screws applied to elevator bolts. Some elevator bolts are placed with heads of bolt above and in the C channel some are below and against the plywood.
Name:	Elavator bolts with insulation.jpg
ID:	17574   Click image for larger version
Name:	Elevator in 1 under.jpg
Name:	Elevator in 2 under.jpg
ID:	17576   Click image for larger version
Name:	Elevator in 3 under.jpg
Name:	Elevator in 4 under.jpg
ID:	17578   Click image for larger version
Name:	Elevator in 5 under.jpg
Name:	Elevator in 6 under.jpg
NorCal Bambi is offline   Reply With Quote
Old 01-11-2006, 10:04 AM   #102
Ken J's Avatar
1956 22' Flying Cloud
Durango , Colorado
Images: 14
My only question/thought is will you be able to tighten the bolt down really good?
Ken
1956 Flying Cloud
Founder :
Four Corners Unit
Albuquerque National Balloon Fiesta
Rally
Vintage Trailer Academy - Formerly the original
restoration rally
Ken J is offline   Reply With Quote
Old 01-11-2006, 10:32 AM   #103
Images: 59
Don,
That looks really neat. Great pictures.
I used an alternate method of putting a little zinc chromate under the head of the screws, and then top dressing with cold galvanizing paint.
I also found some self-drilling hex-head zinc (coated) screws with rubber washers that worked well for the small screws. I coated those with cold galv. paint also.
Old 01-11-2006, 11:05 AM   #104
1963 16' Bambi
Yreka , California
Images: 21
Ken
The bolts tightened up well. The caulking I used also worked to adhere the channel. By using fiber washers I was able to get things really tight. My first try was with rubber washers. That did not work.
Don
Old 01-11-2006, 11:07 AM   #105
1963 16' Bambi
Yreka , California
Images: 21
Originally Posted by markdoane
Don,
Your solution sounds good. Do you have any pics of the screws you used?
Don
Old 01-11-2006, 11:10 AM   #106
1963 16' Bambi
Yreka , California
Images: 21
Back to the Future!
It would be so cool if we could all be here 40+ years from now and compare our dismanteled trailers. And compare our solutions. If nothing else it would be worth several beers and a lot of good conversation.
Don
Old 01-11-2006, 11:27 AM   #107
Images: 59
Don
Here ya r:
Old 01-11-2006, 11:28 AM   #108
Images: 59
Don
You want to set something up? How about your place, January 11, 2046? I'll bring the Zimas.
Old 01-11-2006, 04:46 PM   #109
1963 16' Bambi
Yreka , California
Images: 21
It's a party
I'll be 105. It could happen! I'll bring the SOFT CHEWIES!
Old 01-11-2006, 08:35 PM   #110
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
I'll come! We can take mine apart first, since I did not provide for corrosion protection at all.
Let's see if my Palm takes this date...
Uwe
www.area63productions.com
Old 01-11-2006, 08:41 PM   #111
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
I'll come also, at the rate we are going the Liner should be complete and I will be 100 in September.
Bill
Just my personal opinion
wkerfoot is online now   Reply With Quote
Old 01-12-2006, 10:11 AM   #112
MarkR's Avatar
1951 21' Flying Cloud
1960 24' Tradewind
Folsom , California
Images: 12
Can I come too? Actually that's a Thursday - can we move it to Friday the 12th or Saturday the 13th.
Aluminumbskull with Led Balloon in Drag
Birch Plywood and Aluminum go together like
Peanut Butter and Chocolate
MarkR is offline   Reply With Quote
Old 01-12-2006, 09:04 PM   #113
1963 16' Bambi
Yreka , California
Images: 21
At 105 let's make it a long week end!
Old 01-13-2006, 06:46 PM   #114
1963 16' Bambi
Yreka , California
Images: 21
In to next step - flip
Well I've completed my gantry grain chain hoist setup. I decided that I was too old and the concrete was too cold to crawl under the trailer and work. So I built my lift system. Like in the old airstream pics. Now I'm ready to install the insulation and the belly pans. I'v included some of the flipped pictures.
Don
Name:	btm on sid fnt2.jpg.jpg
ID:	17640   Click image for larger version
Name:	upsddn bk1.jpg.jpg
Name:	upsddn ft2.jpg.jpg
ID:	17642   Click image for larger version
Old 01-13-2006, 06:59 PM   #115
uwe
418
uwe's Avatar
1974 29' Ambassador
Images: 41
And here I thought I was a freak with this stuff.
Bravo, Don!
Uwe
Old 01-13-2006, 07:09 PM   #116
1963 16' Bambi
Yreka , California
Images: 21
I like people who call it the way they see it. Thanks for the positive input.
I take that as a complement coming from Uwe!
Old 01-14-2006, 07:09 PM   #117
1963 16' Bambi
Yreka , California
Images: 21
Belly foam insulation
I'm installing foam for insulation in the belly section of out Bambi. I've decided to do this for a couple of reasons. 1. When I took the belly pans off I found several large bee nests. I want the cavity completely filled with material as a attempt to keep all maner of critters out of the trailer. We'll see. 2. By shaping the foam to match the shape of the aluminum skins I will have greater support under the metal. This should help in the resurfacing of the aluminum. I'm reusing the old belly pans because the metal is still in pretty good condition. They mainly need to be cleaned up and resurfaced. 3. It also gives me an opportunity to put go good use some of my sculpture skills.
Don
ID:	17662   Click image for larger version
ID:	17664   Click image for larger version
Name:	Picture 024.jpg.jpg
Old 01-14-2006, 07:36 PM   #118
Images: 59
Don,
I did mine the same way. . .
Until my wife caught me. . .
using her electric carving knife to shape the insulation!
Old 01-18-2006, 01:46 PM   #119
1963 16' Bambi
Yreka , California
Images: 21
Progress report
I have continued to install the foam on the belly of the trailer. Hopefully I will have the belly finished and flip the trailer back on its wheels in a week. Also I have been working on the Ideas for installation of the insulation of the shell walls. First a picture of current progress.
Old 01-18-2006, 02:16 PM   #120
1963 16' Bambi
Yreka , California
Images: 21
Inner Wall condensation and insulation
Well here goes! I am really looking for your thoughts and ideas, good or bad, on these ideas. This is going to take several posts to explain and diagram the entire idea.
Some basic thoughts that have influenced this design. 1. Cold Metal and moisture in the air is a real consideration in the airstresm. 2. In another thread a person had mentioned that panel experiments had been done by them and they had discovered that the inside temperature of the Airstream shell can easily reach 140+ degrees. 3. Extreme temperature variations between the inside of the trailer and the outside world can create some interesting conditions. 4. Can any of these things be addressed or are we just at the mercy of Mother Nature?
I have looked at many of your threads and the ideas you have applied to your restorations. I have taken many of these ideas and made modifications.
Many have used "Reflectix" insulation in the walls with an air space on either side. This seemed like a good idea to me because it forms two air spaces on either side of the Reflectix insulation. In the discussions on Inner wall condensation thread two items seemed to be keep coming up. !. Air circulation and heat control.
I have used the two air spaces with a Reflectix insulation barrier to create three spaces. The following change I made was to take the outside space and create an air flow circulation pattern. This was done to hopefully help in the removal of condensation moisture. I am adding a new material that I have found. The material is "Dura Cool". It is a filter that has been designed for swamp coolers. It is a relative new material that has some very interesting properties. I am going to do further research on this product. I hope to include a web page or additional information in future threads.
Following is a cross section diagram to illustrate the material. Following will be several posts showing details with further explanation.
Name:	Bamgi Wall Ventelation 1.jpg
ID:	17729   Click image for larger version
Name:	Bamgi Wall Ventelation 2.jpg
