Old 02-04-2006, 08:50 AM   #155
NorCal Bambi's Avatar
Profile:  1963 16' Bambi
Yreka , California
Images: 21
Originally Posted by A-Merry-Can
ah yes... the light at the end of the tunnel... sorta...
jp
ps. my wife was my buckin partner, too... countless jokes with that... i think she got sick of my "bucking" sense of humor...
My wife would probablly like to communicate with yours. She had to go the that "b-ing" joke place this morning. It takes a great wife to but up with all this Airstream stuff. And all the other streams that go with it.
p.s. If you look close in the third picture below, you will see the now famous riveter.
NorCal Bambi is offline   Reply With Quote
Old 02-04-2006, 08:52 AM   #156
Yreka , California
Images: 21
Originally Posted by ankornuta
Oh man... I cannot wait to start getting my trailer back together again; there's a certain feeling of anxiety I get when I see it all in pieces... it just seems so much more vunerable... poor thing
If it wasn't for this forum, none of use would be able to imagine the end of the "Aluminum" tunnel. I wonder if anyone has realized that the bright light was because of all the aluminum?
Old 02-04-2006, 09:58 AM   #157
jordandvm's Avatar
Profile:  2005 28' International CCD
1977 Argosy 22
Western , Oregon
Images: 58
Great Job!
Don & Claudia,
Will be great to share your Bambi progress in person at the rally in Newport.....even after I've read your posts & pics on this thread! BTW, we overnited at Waiika Trailer Haven in Yreka on Jan 6th heading to Yosemite. Almost called.....but we were traveling with friends and were in a hurry.
Jim & Cheryl
2005 28' CCD
1977 22' Argosy
2004 Chevy Avalanche 2500, 8.1L 4.10 rear axle
Prodigy brake controller/Equalizer hitch
Honda 3000 genset
WBCCI #3538
jordandvm is offline   Reply With Quote
Old 02-04-2006, 09:17 PM   #158
Yreka , California
Images: 21
Jim & Cheryl, you would always be welcome!
See ya at South Beach.
Don
Old 02-05-2006, 08:44 PM   #159
Silver Hilton
Mark Wiltrakis's Avatar
Profile:  1992 29' Excella
1959 24' Tradewind
Hillsboro , Oregon
Don -
Today was my first read of this thread. You've done an outstanding bit of work thusfar, and I look forward to reading of future progress. I'm VERY impressed and want to wish you a smooth path to completion of the project.
I was feelin' good about some frame sanding and POR 15 repainting . . . .
Mark
Mark Wiltrakis is offline   Reply With Quote
Old 02-06-2006, 08:05 AM   #160
1977 31' Sovereign
davidh's Avatar
Profile:  Kalispell , Montana
Condensation
Ok this is just my thought on this, it seems to me that you have the belly of your trailer seald so tight, that it will create condensation in the belly, whitch in return will rot the floor in time but you guys really do not need to worry about that, because you are going to inspect them when 105 years old for the long weekend. I read your threads last night, and like you guys lost sleep over the thought of the condensation gremlin that haunts us all. But with air circulatoin by wrights should elimanate condensation. so this was my thought, If you had two vents in the belly one on each side to draw outside air into belly and had one hole drilled through the floor between each wall rib, and the space that you guys are creating for your insulation in the walls, would'nt that create enough air flow thru the belly and walls to elimanate condensation. It was just a thought, you guys are really doing one heck of a project though, and it is really looking good. The documentation that you guys are doing will for sure help others out for generations to come.
1977 31' landyacht Sovereign
davidh is offline   Reply With Quote
Old 02-06-2006, 03:45 PM   #161
Addicted to Aluminum
A-Merry-Can's Avatar
Profile:  1959 18' "Footer"
1964 24' Tradewind
1954 29' Liner
Woodstock , Georgia
Originally Posted by davidh
Ok this is just my thought on this, it seems to me that you have the belly of your trailer seald so tight, that it will create condensation in the belly, whitch in return will rot the floor in time....
but if we totally cure the condensation, what are we gonna do in 30 years for fun?
jp
8576 • • • • • • • •
there's always room for one more!
• • www.toolbox-design.com • •
A-Merry-Can is offline   Reply With Quote
Old 02-08-2006, 10:20 PM   #162
Yreka , California
Images: 21
update
Yesterday Bambi got out of the garage for the first time since last August.
Name:	Out of garage.JPG.jpg
Old 02-09-2006, 12:05 AM   #163
C Johnson's Avatar
Profile:  1965 17' Caravel
Portland , Oregon
Images: 326
Send a message via MSN to C Johnson Send a message via Yahoo to C Johnson
Good work Don ! It is a great feeling isn't it when the shell is back on the frame.
C ya soon
Chris
Chris AIR # 7276, WBCCI # 7276, TAC OR - 8
WBCCI Forum Save Wally Forum
Photos of Project 2k5 My Pictures
C Johnson is offline   Reply With Quote
Old 02-09-2006, 09:47 AM   #164
1964 24' Tradewind
1954 29' Liner
Woodstock , Georgia
now the fun begins! congrats!
jp
Old 02-09-2006, 09:26 PM   #165
Yreka , California
Images: 21
Fun, Yes. I have been installing wiring and trying to figure out what I want. Here is a question. The tail lights on my 63 CA Bambi have two bulbs in each fixture, and a total of three elements. One small bulb with a single element. and a larger bulb with two elements. The twin element bulb is a standard tail light stop light bulb. So far I have used the original wiring. It is that wiring that leads to my question. First the details, The small bulb is wired in with the clearance lights and lights when power is applied to that wire. The large bulb has a wire that lights the tail light elements in both sides of the trailer. The Stop/turn signal elements work standard. Here is the question, What was the purpose of this system of wiring? One of my thoughts is that one of the lights was used as a backup light, even though it would be a red light. In a seven wire umbilical one connection is for backup lights. This trailer never had white backup lights. Although it was wired for them. Second, maybe in 1963 cars had a lighting system where you could turn on the clearance lights separate from the tail lights. I will be using a 6 wire umbilical because the rest of my trailer equipment is already 6 wire. I will probably combine the clearance light wire with the tail light wire for a contemporary connection.
Anyone have any thoughts?
Don
Old 02-09-2006, 09:54 PM   #166
uwe
418
uwe's Avatar
Profile:  1963 26' Overlander
1958 22' Flying Cloud
1963 19' Globetrotter
Portola Hills , California
Images: 41
Don
Don,
I remember there being a thread on this very issue. I can't find it though.
My lights were wired the same way originally. I need to take a look at how it is now. It works great, but I might have changed the electrical layout slightly.
Combining the 2 wires should work fine, as it is like that in newer trailers.
Uwe
www.area63productions.com
Old 02-09-2006, 09:55 PM   #167
C Johnson's Avatar
Portland , Oregon
Images: 326
HI Don, On the tailights, I think you have the right idea. That is how I did mine. I have the exact same lights as you do. I wired the smaller bulb with the running lights/tailights. Works just fine.
On the umbillical cord here is what I suggest and what I did. I bought 25 ft of 7 way cord. Enough to go the length of the trailer right up to the tailights plus about 2 ft out the front. I did put OEM backup lights on my trailer. I am glad I did. IF you didn't want to go that route just now, with the 7 way cord at least the wires would be there should you change your mind later on down the road. You can still put a 6 pin connector on it and fold over the unused wire for now. Just a thought.
Chris
Old 02-09-2006, 10:01 PM   #168
Profile:
What was the purpose of this system of wiring? One of my thoughts is that one of the lights was used as a backup light, even though it would be a red light. Anyone have any thoughts?
Don
Uwe solved my problems with this... I think cars used to have a separate brake and turn signal - so the different filaments served these two purposes. They make circuits that combine your tow vehicle brake and turn signals if you have one of those older cars and want to pull a newer trailer.
As for the umbilical, I wired mine up with a jack on both the tow vehicle and airstream so that my cable is completely detachable. It works well and from the looks of my original cable, the elements aren't good to that wire after a few (44) years.
Carlos
jcferguson is offline   Reply With Quote
1961 - 1963 Bambi Serial Number Guide Andy R 1961 - 1963 Bambi 40 10-28-2009 07:07 AM
1961 Bambi '16 (Serial #16TDSS1728) Andy R 1961 - 1963 Bambi 20 05-14-2007 12:28 PM
Newbie AS Bambi Owner! KY Girl Our Community 12 10-27-2002 09:06 PM
Interior lights - 61 Bambi 61BambiCanada Electrical - Systems, Generators, Batteries & Solar 0 06-07-2002 09:52 AM
Bambi II is a Caravel... VintageRV 1964 Bambi II 0 02-24-2002 07:55 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
