Old 10-27-2007, 07:28 PM   #1
1959 24' Tradewind
Excelsior , Minnesota
Floor replacement 59 TW beyond the frame?
Hi,
Heres the deal, I have a 59 Tradewind I have taken down to nothing. The top is sitting on the stripped and repaired frame very tenatively. I am in process of cutting new wood floor and cannot remember the pattern of the old. Does it go beyond the steel frame or does it just come up to it. I know where the outriggers are it obviously goes beyond but along the sides and possibly the back I can't remember. Wish I hadn't thrown the old out. It is about 7 ft plus about 3-4 inches across the cross beams. I think a blueprint would be helpful but can't find one. Can anyone help me???????????????
Thanks so much!
Betsy
betsy is offline   Reply With Quote
Old 10-27-2007, 07:42 PM   #2
byamcaravanner's Avatar
1967 28' Ambassador
1963 19' Globetrotter
1970 29' Ambassador
Waukesha , Wisconsin
The width of the plywood on my '67 is 15 1/4" past the main fraim rails which are 58" apart. So, doing the math, that comes to 88 1/2" wide.
I can't say if the '59s are the same though.
Steve & the crew
'70 Ambassador International Twin
'63 19' Globetrotter TAC WI-1
http://byamcaravanner.blogspot.com/
byamcaravanner is offline   Reply With Quote
Old 10-27-2007, 09:10 PM   #3
Images: 59
Betsy,
Mine is 88 inches. The plywood overhangs the outriggers equally by about 1/4" on each side. If you need the actual front to back dimensions I can dig them out tomorrow. I had the whole thing plotted on Autocad.
Is your Tradewind a California or a Ohio model?
Floor Replacement & part of the frame Angel73 Repairing/Replacing Floor &/or Frame 6 05-23-2006 08:57 AM
Floor Replacement - Frame Weld pinkflamingoes Repairing/Replacing Floor &/or Frame 9 01-04-2006 07:54 PM
Price for floor replacement and frame repair 68Glbtrotter Repairing/Replacing Floor &/or Frame 35 12-06-2005 11:28 PM
Shell-on, frame repair/floor replacement all at once?? pinkflamingoes Repairing/Replacing Floor &/or Frame 12 09-13-2004 05:11 PM
