Prev Previous Post   Next Post Next
Old 08-17-2009, 08:52 PM   #1
Profile:  1968 20' Globetrotter
steamboat Springs , Colorado
Floor replacement
I have a 68 GT. Im in the process of doing a compleat floor replacement. My issue is trying to remove the belly end skin. I have started to remove the lower rivets and trim.
The lower belly ends are tucked under the main ex-skin and riveted to the lower frame rails. I can't get to the rivet under the ex-skin. Should i remove more rivets higher up on the ex-skin making more room to pull back the ex-skin or should i trim back cutting 1/4 to 1/2" of the lower ex-skin letting me have more working room and getting to the hidden rivets?
Also it looks like once i finish this process i won't have any lower support to lift the body off the trailer.
I have read some other posting but did not come across this.
Any other info will help.
68GTAir is offline   Reply With Quote
sub floor replacement help Terry J Repairing/Replacing Floor &/or Frame 12 03-31-2009 09:30 PM
Which Floor Replacement? gc24 Repairing/Replacing Floor &/or Frame 28 06-17-2008 01:26 PM
Floor replacement Over59 1958 - 1963 Overlander 5 09-12-2004 02:24 AM
Floor Replacement ????'s daveinbama Repairing/Replacing Floor &/or Frame 8 08-07-2004 03:05 PM
floor replacement daves clipper Repairing/Replacing Floor &/or Frame 18 01-04-2004 07:26 AM
