Old 03-05-2008, 04:17 PM   #1
Boise , Idaho
Floor replacement
Is there a way to replace the floor without doing a frame off procedure?
Dman is offline   Reply With Quote
Old 03-05-2008, 04:52 PM   #2
toastie's Avatar
1955 22' Safari
Great Lake State , .
Check this out:
1956 Flying Cloud - Floor
You would probably better off to drop the belly pan and raise the shell......
toastie is offline   Reply With Quote
Old 03-06-2008, 09:18 PM   #3
Boise , Idaho
Floor Replacement
Will this type of floor replacement affect the structural intergrity of the airstream?
Old 03-07-2008, 02:35 AM   #4
byamcaravanner's Avatar
1967 28' Ambassador
1963 19' Globetrotter
1970 29' Ambassador
Waukesha , Wisconsin
If you do it right, you can replace the floor to exactly as it was originally installed. this requires removing the belly pan and the lower interior skins. What length trailer do you have?
Steve & the crew
'70 Ambassador International Twin
'63 19' Globetrotter TAC WI-1
http://byamcaravanner.blogspot.com/
byamcaravanner is offline   Reply With Quote
Floor Replacement ????'s daveinbama Repairing/Replacing Floor &/or Frame 11 12-13-2010 11:11 AM
Floor replacement thickness soldiermedic Repairing/Replacing Floor &/or Frame 31 03-26-2007 01:15 PM
another floor replacement question durans54 Repairing/Replacing Floor &/or Frame 32 02-01-2007 12:29 PM
Floor replacement Over59 1960 - 1964 Overlander 5 09-12-2004 01:24 AM
floor replacement daves clipper Repairing/Replacing Floor &/or Frame 18 01-04-2004 06:26 AM
