Old 04-14-2015, 05:33 AM   #1
mprokop87's Avatar
1978 28' Argosy 28
Victor , New York
Floor replacement
I have cut out a section of the floor in my Argosy because it was damaged by water. I made a replacment out of plywood but it seems more flexible that the rotted floor that was in there! Is there a better material to be using for floor replacement? I thought a plywood with the same number of layers would do.
I still have to put a subfloor over it so I can finish laying the parquet flooring back down. Just want to make sure I am doing this right since I had to almost destroy my galley cabinets.
mprokop87 is offline   Reply With Quote
Old 04-14-2015, 06:59 AM   #2
mimiandrews's Avatar
1966 22' Safari
Hilltop Lakes , Texas
Is the thickness of the new plywood the same as the old?
Old 04-14-2015, 07:01 AM   #3
mprokop87's Avatar
1978 28' Argosy 28
Victor , New York
Yes it is. It is 1/2 inch. The area i replaced is under the cabinets where the furnace would sit so I am not too worried about it. I am just happy that there is no longer a 6 inch hole where mice could get in!
Old 04-14-2015, 07:28 AM   #4
1972 25' Tradewind
fort lauderdale , Florida
Do you have any pics of the area to be patched?
You may be able to screw a 2x4 on the back (underside) of the plywood as a stiffener.
ehodg66 is offline   Reply With Quote
Old 04-14-2015, 07:38 AM   #5
mprokop87's Avatar
1978 28' Argosy 28
Victor , New York
Thats a darn good idea, can't believe I didn't think of it. I will do that tonight and put it back together. Thank you!
Old 04-14-2015, 09:08 AM   #6
1972 25' Tradewind
Maybe something like this....
Floor Problems - Water under wood floor Ramblinboy Repairing/Replacing Floor &/or Frame 2 05-19-2012 09:58 AM
Floor Newbie - Tile floor DanielB Floor Finishes 15 06-15-2011 07:14 PM
What to do - Above floor Tank or Below floor tank ??? fatwgn Sinks, Showers & Toilets 8 09-06-2009 02:50 PM
Pictures of shell off floor replacement... williamhenshall Repairing/Replacing Floor &/or Frame 23 08-08-2002 05:05 AM
