I can truthfully say that replacing a section of floor and going through a divorce are much the same. You can't imagine the the surprises that await and you'll never want to do one again.
Annie and I stripped the inside of our "new" Overlander last Saturday to get ready for a fresh interior. Having extensive experience with wooden boats, I probed the floor to look for rot. Naturally there was a soft area under the front window. So I read every thread I could find on how to replace the section. After I had removed the interior skins and drilled out the bottom row of rivets on the exterior I thought - "I'll have this done tomorrow". Well, three days later I'm fitting new belly skins. I ended up having to replace the floor across the front and down the side to the door. Yuk. I thought the hard part was done when I had the insulation back in place, the channel bolted down and was ready to fit the new section of underbelly. The .040 aluminum is not nearly as easy to work with as the original. Anyway, I'm supposed to get pics back tomorrow so I post some. It just feels like I should have more to show for 40 hours work. I've replaced planks and frames on my old Chris Craft with no where near this amount of labor.
I'm going to go soak for a while.
Paul & Annie
"No matter where you go, there you are..."
WBCCI #7162 AIR #1565
Yes, a little rest went a long way towards wanting to crawl under the trailer again. It just all looked so simple. (My famous last words) Anyway, here is a snapshot of the progress, this just before I started fitting the belly pan.
Paul & Annie
Originally posted by Jabba Ok John, explain to us how one takes out a toilet with your forehead, this is a new approach that has me curious.
jason
it works like this:
i had an old fashioned two part toilet, the stool on the floor and the tank on the wall. it was connected by a chrome pipe.
thinking i would save some time i left the tank mounted to the wall and pulled just the stool.
when i was nailing in the new subfloor (remember, all i'm doing is painting the bathroom) the vibration from hammering detached the tank from the wall! i looked up just in time to see the tank hit me in the forehead. needless to say it broke into a zillion parts!
that is how you break a toilet with your forehead!
Sounds like something they should have put in "Home Improvement" or This Old House Funniest Out takes... I cringe at the thought, I bet you saw stars for a while!
Jason & Veronica Jablonski
1955 Commodore Vanderbilt/Liner 30'
