| Floor Repair
Finally got around to fixing the damaged floor in our 22' International. Cut out the damaged section and replaced with 5/8" plywood glued and screwed to the frame rails. Added some insulation as what was there was definitely lacking.
After much thought we decided on finished 3/8" plywood as the final floor covering, glued and screwed to the OSB subfloor. We finished the plywood with stain and 2 coats of polyurethane.
Overall we are very pleased with the results. We also modified the very uncomfortable dinette setup to increase floor space and have something more comfortable to sit in. Will post pics of that in another thread. jk
