Old 03-26-2015, 09:35 AM   #1
1964 19' Globetrotter
eagle , Idaho
Floor Repair
I've got rot in my floors in the front corners it looks like. None in the bathroom so far.
What is the best way to repair and seal these using the patch method?
I really don't want to go frame off if I don't need to but I also want a quality end result.
thoughts?
i'll try and get pictures soon.
thanks,
idahoair is offline   Reply With Quote
Old 03-26-2015, 03:09 PM   #2
1981 31' Excella II
New Market , Alabama
You can cut out a square piece and then attach pieces below the floor for the patch to rest on. You really need to find the leaks first. The rear end of the trailer is also suspect. If the rear end if rotten it gets more involved. Best way to find leaks is to remove inner skins and sit out there in the rain.
Perry
Old 03-26-2015, 07:09 PM   #3
aquinob's Avatar
Portsmouth , Virginia
A rotten section in the front is not nearly as bad as one in the rear. The front is supported by the frame to the ball and the weight of the shell holds it down. If the floor is rotten in the front, there is not that much stress or movement so a patch should do the job.
In the rear, the frame is unsupported and will want to drop down and separate from the shell when the floor rots. So replacing a larger section is usually warranted to keep the structure intact. A frame off should be a last resort if there is extensive damage to the floor and frame.
When you can post some pictures of the damage, it will be easier to advise on how to repair it.
Ongoing adventures at:
http://1973overlander.blogspot.com/
aquinob is offline   Reply With Quote
Old 03-27-2015, 06:05 AM   #4
1981 31' Excella II
If the damage in the front is where the attach points are then that is a problem. It sounds like the damage is in the transition area which is not structural. Damage has to be really bad on both ends to warrant a shell off.
Perry
Old 03-27-2015, 10:26 AM   #5
eagle , Idaho
thanks for the insight.
as far as we can tell the rear looks good.
I'm hoping the front door and the front corners are the worst of it.
Old 04-16-2015, 07:55 PM   #6
eagle , Idaho
Pics
ID:	236445   Click image for larger version
Old 04-16-2015, 08:25 PM   #7
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
I dried then applied "git rot" epoxy. West Marine has it. Poured a lot near the wall. Soaked in a lot! I drilled many many holes halfway into the floor and injected the epoxy inside... Nice easy fix!
Peace and Blessings..
Channing
WBCCI# 30676
Old 04-16-2015, 11:27 PM   #8
eagle , Idaho
Good idea. We cut pat out the other sections are solid but look to have damage. So the epoxy may be the trick
Plastic bathroom components crack repair with 3M 4240 semi-rigid plastic repair kit Top Upholstery, Blinds, Walls & Interior Finishes 1 05-09-2011 07:11 PM
shop repair of 1970s rear frame separation (non elephant ears repair) RV shop review simonhanbury Repairing/Replacing Floor &/or Frame 49 06-24-2008 09:16 AM
Excuse my ignorance (Floor repair question) 59toaster Repairing/Replacing Floor &/or Frame 15 02-19-2003 12:20 PM
floor repair and divorce Paul Mayeux Repairing/Replacing Floor &/or Frame 7 02-11-2003 08:32 AM
Bathroom Floor Repair John Sims Repairing/Replacing Floor &/or Frame 4 01-09-2003 12:13 AM
