Old 09-29-2007, 10:17 PM   #1
1966 26' Overlander
Conover , Ohio
floor question
I am replacing the rear section of floor on my 66 Overlander due to a neglected plumbing leak. I noticed that the outermost flooring bolts (red circle) on the crossbraces were upside down. Since I haven't completely gutted the interior yet, I was wondering if these bolts connect the wall ribs to the floor? And if this is the case, this sound like a tough piece of plywood to replace. Many of the floor bolts are rusted and bent like the one in the pic. Since the rest of the plywood flooring is in good shape is it worth my time to replace most of these to tighten the floor up ? Any thought from someone who has been there? Thanks, Tom
air66stream is offline   Reply With Quote
Old 09-30-2007, 12:50 AM   #2
FreshAir's Avatar
1966 24' Tradewind
Placerville , California
Airstream purposely bent the flooring bolts to prevent them from working loose. They knew these coaches were/are going to last! So you will have too cut, break or drill them out. On mine where the floor rotted the old ply was easy to pull up over the bolts. Now along the outer wall the bolts go though the body C-channel, through the ply floor and through the outriggers and or frame. You will have to remove the inner skin to get at them or create access panels that can be patched later. I would use access panels where they will be hidden in closets or behind cabinets.
Neil and Lynn Holman
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
1969 Oldsmobile Ninety Eight
455 cid
Old 09-30-2007, 06:36 AM   #3
byamcaravanner's Avatar
1967 28' Ambassador
1963 19' Globetrotter
1970 29' Ambassador
Waukesha , Wisconsin
Tom,
I'm in the process of doing the exact same thing on my '67. I have gutted my trailer (really doesn't take that long) and have removed the bottom interior skins. Take a close look at the entire floor from the top. Nearly all of mine looked good from the bottom but after I got access to the top edges from the interior I found that the wood at the perimeter is pretty punky. I am now replacing the entire floor.
I found the best way to remove the floor bolts is to use a saws-all. I use a 9" fine tooth blade and cut the bolts between the frame members and the floor. The space occupied by the sandwiched insulation allows the blade to easily fit between the frame and floor.
Good Luck!
Steve & the crew
'70 Ambassador International Twin
'63 19' Globetrotter TAC WI-1
http://byamcaravanner.blogspot.com/
byamcaravanner is offline   Reply With Quote
Floor question AirMillie Repairing/Replacing Floor &/or Frame 2 09-28-2007 04:41 AM
another floor replacement question durans54 Repairing/Replacing Floor &/or Frame 32 02-01-2007 12:29 PM
Floor Question higgy116 Repairing/Replacing Floor &/or Frame 11 07-19-2006 11:25 AM
1 more question on floor replacement? jperryfly Repairing/Replacing Floor &/or Frame 2 06-15-2004 09:59 PM
Floor support question jeanarlene Repairing/Replacing Floor &/or Frame 1 10-11-2002 10:26 AM
