Does anyone have accurate measurements of the floor shape for a
1963 Globetrotter? I measured the floor width and length as I dismantled it but all 4 corners were badly rotted and not good enough to make patterns.
I did make a pattern of the inside edge of the u-channel in the front corner and noticed that the rear was close but not quite the same and I'm concerned that I'll cut to that pattern and it won't be close enough when I set the shell onto the new u-channels.
If I can't find the measurements, then I'll have to set the shell down and trace it's profile and then remove it to cut the plywood and make the new belly pan.
I'm also open to other suggestions.
Matt
