07-10-2015, 11:39 AM
1973 29' Ambassador
Def
, Michigan
Floor Plywood Question!
Hey all,
Just getting ready to put in my new floor and have a question for my
73 Ambassador...
Do the sheets of ply need to be cut, or is the width of the trailer 96"? I've been searching for a while now and can't find anything.
Thanks!
Coston
1973 Airstream Ambassador
07-10-2015, 12:30 PM
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View
They need to be cut....to about 84 inches. Measure an remeasure, then cut. The 4 ft widths work well and then you have to make a pattern for the rounded ends...front and rear.
07-10-2015, 12:37 PM
1973 29' Ambassador
Def
, Michigan
Outrigger to outrigger is 91". Cutting at 84" doesn't seem right...
Coston
07-10-2015, 04:05 PM
2006 22' International CCD
1957 26' Overlander
Plymouth
84" is the width of the floor for some years. As time passed trailers got wider. Make sure to cut your floor the correct width for your trailer. My 57 over lander is 84" wide
07-10-2015, 04:12 PM
1963 16' Bambi
1962 22' Safari
Yreka
When my husband installed the new plywood floor on the previous Flying Cloud he partially restored, once the plywood was in, he put some sort of epoxy or wood hardener around the edges so if for some reason a water leak would come from the outside it wouldn't seep through and damage the flooring.
07-10-2015, 07:15 PM
1979 23' Safari
Wayland
, New York
My '79 was 92" across. You Need to measure the old wood, hopefully you still have some to measure. If not 92" is probably a good start.
Do you have c channel along the sides that encloses the plywood edges?
You can paint the top of the floor with deck and porch paint. Prime first. It'll help protect it. Keep the underside un painted so if the wood does get wet it has a path to dry.
I wrapped the front and rear from where the curve starts on one side to the other in aluminum tape. Several layers thick and in about 1.5" from the edge. Protects from water.
Drain holes in the c channel. Drill small 1/8" ish holes around the perimeter on the outside lower corner, that way any water that gets in the channel can drain to the belly between the outer skin and belly wrap.
07-10-2015, 08:02 PM
1981 31' Excella II
New Market
, Alabama
It needs to go in under the walls and be attached to the C-channel at the bottom of the walls. There are also structural attached points at the front and back that need to be repaired.
Perry
07-12-2015, 08:14 AM
1973 29' Ambassador
Def
, Michigan
Thank you all for the help!
Coston
07-12-2015, 10:30 AM
1971 21' Globetrotter
Arvada
Measure from the outside to outside of the "C" channel, should be in the 92 range for your year, use the cut off portion for new splice plates.
07-28-2015, 09:55 PM
1975 Argosy 28
1975 Argosy 22
1978 Argosy Minuet 6.0 Metre
Camrose
, Alberta
take a few measurements. Mine was average 92. some places 89, some 93.5, etc
10-04-2015, 06:38 PM
1966 24' Tradewind
Kansas City
, Missouri
My old front end piece is in good enough shape to use for a pattern; the rear piece, not so good. Can I use the front as a pattern for the rear? Same shape, no?
10-05-2015, 01:37 PM
1979 23' Safari
Wayland
, New York
No, it's a different shape.
10-05-2015, 08:24 PM
1966 24' Tradewind
Kansas City
, Missouri
How so?
10-05-2015, 10:24 PM
1979 23' Safari
Wayland
, New York
The rear curve is longer and more gradual. Not as sharp in the corners and continues forward farther than the front goes back.
10-14-2015, 11:46 AM
Paw stuck
, Connecticut
Hi does the plywood have to be in one 4'x92" piece with shell on partial replacement that large of a piece is difficult to maneuver in place.
10-14-2015, 12:37 PM
1951 21' Flying Cloud
1960 24' Tradewind
Folsom
It depends. If you're replacing the last 2 or 3 sheets of plywood you can usually pry/separate (gravity might even take care of it) the frame from the body enough to slide the panels in 1 at a time. If you're replacing a single sheet in the middle of the trailer you can "split" the plywood so you have (2) 46" x 48" pieces and install a "cleat" down the bottom middle to "sew" the sheet back together. The "cleat" would be a something like 6" wide and I'd glue and screw it (generously) the length of the seam - there'll be an "interruption" in the cleat at the "intermediate" cross member.
Good Luck
Aluminumbskull with Led Balloon in Drag
Birch Plywood and Aluminum go together like
Peanut Butter and Chocolate
10-14-2015, 01:03 PM
Paw stuck
, Connecticut
Hi thanks for reply...I don't want to take shell off I have removed bolts in c channel so plywood should fit nicely the pieces i'm replacing were plywood that was cut in sections as long as they are bolted and secured do you think that is a way to go I can't handle hugh pieces of plywood
10-14-2015, 02:42 PM
1960 24' Tradewind
Folsom
. . . that was the version where you don't have to remove the shell HOWEVER, the Belly Pan would have to be detached to do what I described above . . . and it sounds your skin-to-channel-to-belly pan is all still attached - photos would be helpful BUT basically if there isn't a Cross Member below any of your proposed joints you need to install a substantial "cleat" below the joint.
10-15-2015, 01:10 PM
Paw stuck
, Connecticut
Another big problem is removing the old rusted bolts I've cut away where I could can you recommend a tool that will cut away the ones in c channel that won't unscrew and are still holding plywood??? nitemare
10-15-2015, 02:04 PM
1960 24' Tradewind
Folsom
Is the belly pan still in place? Again, I'm assuming it is. If it's elevator bolts "out in the field" of the plywood, you can set your skill saw for a 5/8" deep cut and cut out a small square around the bolt head, break up the remaining little plywood square and then use a bolt cutter to snip it off or a cut off wheel . . . If it's bolts out at the perimeter in the bottom wall track, thru the plywood and into the outriggers, AND everything (belly pan, outer skin) is still attached then you may need to take a "happy pill" and keep working on it. You might try a reciprocating saw and try to be as parallel to the side as possible (so you don't run the blade thru the side of the ext. skin) . . .
