Old 07-25-2007, 12:18 PM   #1
Profile:  Fountain Hills , Arizona
Floor patch / sealant
Hello. I am getting ready to do some floor work on a 72 Sovereign. The plywood is rough in a couple areas, so I'm planning on doing some 'on shell' patch work.
I couldn't find any threads that spoke about a good sealant to utilize after the patch is made. Could somebody recommend a good path and/or sealant once the patch plywood is put in place.
My preference would be to utilize this same sealant over the entire floor as I am planning on tiling afterwards.
Thanks in advance.
Jpomie is offline   Reply With Quote
Old 07-25-2007, 02:20 PM   #2
Happycampers's Avatar
Profile:  1979 30' Argosy
Peterborough, , Ontario
Hi Jpomie, Welcom to the forum, I am not exactly sure what you are wanting to do but I am doing some patches in my floor and I am going to use fiberglass resin, I don't know how it woruld do for doing the whole floor, I know I did tile in a bathroom of a house one time and didn't put anything on the wood floor. I will be doing my floor in a couple days and will be posting on Costalotta Start to Finish thread if you want to see how I am doing mine. Marvin
Marvin & Annie
Toby & Niki (fur babies)
1979 Argosy 30
WBCCI 10103
2005 F250 Lariat Power Stroke Diesel Crew Cab 2wd
"Happiness is a warm Puppy" Charles Schulz
Happycampers is offline   Reply With Quote
Old 07-25-2007, 02:40 PM   #3
BoiseState
Spiffy Gem's Avatar
Profile:  1966 22' Safari
All my life in , Idaho
Images: 36
Thanks in advance.
Patch work material and sealant are two different things.
Others have used different products, but I personally used bondo to fill in the seams, after using corrugated fasteners, as patch work material. The bondo will crack and break away if you do not fasten the joint. Additionally, your choice of flooring material is limited if the joint allows movement.
I observed this first hand: I decided that using corrugated fasteners was a waste of time, after using them on the first seam between two sheets of sub-flooring, and decided not to use them on the other seams. Then came hunting season, and my wife insisted I take the Gem out hunting, after all, though there was no insultaion or finished flooring installed, it was better than using a tent. When I got back home and inspected the floor, the bondo had cracked everywhere except where the corrugated fasteners had been used. I had to redo all the other seams after installing the fasteners every 4-5 inches.
I eventually used glue-down cork for flooring, and have boondocked in some rough places and have no cracks in the floor.
For sealant, I used marine epoxy, which I bought at a local boat repair shop. One quart covers about 32 square foot, and is normally used around the outside edges, where the shell attaches to the floor. You want to be careful not to create a situation where the floor gets wet and the epoxy keeps it from drying out.
Calvin
Spiffy Gem is offline   Reply With Quote
Old 07-25-2007, 02:49 PM   #4
BoiseState
Spiffy Gem's Avatar
Images: 36
FYI: a corrugated fastener picture:
Old 07-25-2007, 03:00 PM   #5
byamcaravanner's Avatar
Profile:  1967 28' Ambassador
1963 19' Globetrotter
Waukesha , Wisconsin
I've used some of the wood restoration products from Abataron for the historic building restorations I've managed. I plan on using these materials to consolidate the plywood floor in my '67 where the damage is very minimal. This stuff can also be used to make major structural repairs though.
Steve & the crew
'67 Ambassador International Twin
'63 19' Globetrotter
http://byamcaravanner.blogspot.com/
byamcaravanner is offline   Reply With Quote
Old 07-27-2007, 01:40 PM   #6
Originally Posted by wader
I've used some of the wood restoration products from Abatron for the historic building restorations I've managed. I plan on using these materials to consolidate the plywood floor in my '67 where the damage is very minimal. This stuff can also be used to make major structural repairs though.
Here is a link Products Overview - Wood Restoration Materials - Abatron, Inc.
Steve & the crew
Old 07-27-2007, 05:40 PM   #7
Profile:  1972 25' Tradewind
Rogers , Arkansas
I recently patched my floor. Following advice from the forum, I cut back the bad area to make sure the patch would rest on two outriggers and one frame rail. The patch is screwed into the outriggers, frame rail and "C" channel. I used an epoxy wood rot repair product for the seams. I've installed cork floor tiles over mine.
Preston and Marilyn
AIR#809
pepper48 is offline   Reply With Quote
Pingbacks are On
Which Sealant Where? Jabba Leaks - Weatherstrips, Gaskets, Caulks & Sealants 16 02-05-2007 08:03 PM
Sealant for holding tank & dump fittings? wayner1239 Waste Systems, Tanks & Totes 8 04-06-2006 06:58 PM
Sealant Products - Exterior & Interior Cat Leaks - Weatherstrips, Gaskets, Caulks & Sealants 21 02-12-2003 10:00 PM
sealant Chuck Leaks - Weatherstrips, Gaskets, Caulks & Sealants 6 11-06-2002 08:41 AM
Vulkem sealant Stougard Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 07-01-2002 12:25 PM
Cooking Forum - Sailing Forum - Early Retirement
Airstream Trailer Forum - Aquarium & Reef Forum
Royal Forum - Book and Reader Forum - Yoga Forum
Volkswagen Touareg Forum - Jeep Wrangler Forum
Whitewater Kayaking & Rafting Forum - Yoga Forum
Interference - U2, Pop Culture & Social Responsibility
Search Engine Friendly URLs by vBSEO 3.2.0 RC8
