Old 08-05-2004, 06:23 PM   #1
Images: 59
Floor is laid
Finally laid the floor for my '59 Tradewind. I plan to raise the wheel wells about 1", so I built a petticoat for the existing wheel wells. I will rivet the old fenders to the extensions once I have the shell back on.
Old 08-05-2004, 07:53 PM   #2
greg176's Avatar
Gabriola Island , British Columbia
Thumbs up
Looks great Don. Do you find the frame much stiffer with the floor on?
greg176 is offline   Reply With Quote
Old 08-05-2004, 09:53 PM   #3
Images: 59
Sujectively, yes. I forgot to check load deflection before I put the floor on. Now that it's on, if I bounce on the rear the tongue lifts off the ground.
Old 08-05-2004, 10:27 PM   #4
JohnG's Avatar
Looks great Don,
I hope your extensions fall into place without any problem when you place the shell back on, but I'm sure you measured it all time and time again to make certain that it would fit correctly.
When do you plan on setting the shell on?
Just adding my 2¢ worth
John G
___________________________
1975 31ft Sovereign International
........Rear Bath Double Bed Model
Tow Vehicle:1999 GMC Serria SLE Classic 1500 5.7Ltr
System: Jordon 2020 Ultima Brake Controller
Hook-Up: Equalizing Hitch and Sway Bar
JohnG is offline   Reply With Quote
Finally, got started ~ 53flyingcloud Cleaning, Stripping & Polishing 512 10-03-2017 11:32 PM
What did you get done? thenewkid64 General Repair Forum 215 03-11-2007 11:19 PM
