Old 03-24-2007, 12:48 AM   #1
cuyeda's Avatar
Long Beach , California
Floor insulation? Material?
What type of floor insulation is used?
After lifting the entire sub-floor out, exposing the belly pan, there was very little original fiberglass insulation. After reading another thread, someone used a double sided foil material. This is not my trailer, someone elses picture for reference.
This looks like a great idea, but wonder if this is overkill or a great idea? I was thinking of adding the regular insulation over the top to fill the air space.
What do others think?
cuyeda is offline   Reply With Quote
Old 03-24-2007, 05:38 AM   #2
boatdoc's Avatar
1973 Argosy 26
Norristown , Pennsylvania
Floor insulation.
Hi cueda; Insulating the floor with a double faced foil insulation such as Prodex or Reflectix is definitely not a overkill. This insulation averages above 14.0 R value and is even more effective when you provide air barrier on each side. There are many threads on insulating the AS including one by me titled "Quest for a new Stainless steel Frame" if you use search forum. Thanks, "Boatdoc"
boatdoc is offline   Reply With Quote
Old 03-24-2007, 08:19 AM   #3
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
Originally Posted by boatdoc
... This insulation averages above 14.0 R value and is even more effective when you provide air barrier on each side.
wow. where'd you get that number? I didn't think they even claimed that much on the label...
(I don't doubt you; just wonderin').
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 03-24-2007, 08:27 AM   #4
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Riverhead , New York
Not overkill, cheap about 25 cents a square.
JUST do it that way you'll love it.
I saw R-14 also.
'77 Sovereign Intl 31' CB
Old 03-24-2007, 09:27 AM   #5
Janets Husband's Avatar
1977 Argosy Minuet 6.0 Metre
1964 26' Overlander
1977 25' Tradewind
Eastern , Washington
Bubble seems to be the way to go. I will be using it in the walls and floor.
Try this site for further info. Insulation 4 LESS They claim R 14.1 with the proper Air Spacing.
Peace
Gary
Janets Husband is offline   Reply With Quote
Old 03-25-2007, 02:50 AM   #6
boatdoc's Avatar
1973 Argosy 26
Hi Chuck; I think LIpets just second my statement. Thanks, "Boatdoc"
Old 04-08-2007, 07:35 AM   #7
cuyeda's Avatar
I wonder if the bubble foil insulation at Home Depot or Lowes, has similar "R" values. Othewise, I will be revisiting the "insulation 4 less" referral.
Thanks for the input and vote of encouragements.
Old 04-08-2007, 08:16 AM   #8
Full-timer
1971 27' Overlander
Pumpkintown , South Carolina
The stuff at Lowes is Reflectix. Note that advertized R-values (anywhere from R-3 to R-14.6) are for whole assemblies with very specific construction details -- particularly air spaces and infiltration sealing. Reflectix itself measures R 1.04.
It's not the heat, it's the stupidity.
Foureagles is offline   Reply With Quote
Old 04-08-2007, 08:19 AM   #9
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
From Insulation4less web site:
R Values for single layer foil-bubble-foil
Heat flow down: 14.1
Heat flow up: 4.9
Heat flow horizontal: 6.2
So - for heating the interior the foil-bubble-foil insulation will yield the R-14 if applied as specified; for cooling the interior the heat flow will be 'up' and the foil-bubble-foil BEST CASE will be R-4.9. I've posted this before but R-14 keeps getting repeated for some reason.
For my floor-on belly rehab I used foil-foam-foil with a single sheet held off from flooring by a single layer (.25") 2" wide strip around periphery accessible floor (between the stringers & outriggers) and used two layers at center to provide some drainage if/when liquid moisture invades the area.
http://www.airforums.com/forums/307547-post26.html
Wabbiteer is online now   Reply With Quote
Old 04-09-2007, 11:27 AM   #10
1973 31' Sovereign
Portland , Oregon
Images: 22
I don't think that heat flow and R value ratings tell the whole story when it comes to reflective insulation. It is my understanding that the measure of heat flow has to do with heat transfer by conduction through the material being tested. While it is true that warm air rises to the top of an Airstream it is also true that a very large percentage of heat loss through the ceiling and walls is not by conduction or convection but by direct radiation. I don't recall the exact numbers at the moment but radiant heat loss through the ceiling is something greater than 90% of the actual total heat loss while it runs something in the high 80's through the walls. Relective foil insulation stops about 97% of the radiant energy transfer (according to the same rating chart at Insulation4Less). The direction that radiant energy is traveling depends on whether it is warmer outside the AS or inside. During the summer radiant energy is trying to get into the trailer while it is trying to get out during the winter.
Even if it were true that the maximum effective value of reflective foil was only a product of its R value it would still be as good as fiberglass insulation. Firberglass has an R value of something like 3 per inch which puts it at about R 4.5 for an airstream wall. Fiberglass, however, does nothing to stop the flow of energy by direct radiation. So my question is how could fiberglass of the same R value as reflective foil possibly be as good as the reflective foil? I have personally run tests on the amount of radiant energy that gets through various types of airstream wall insulation construction. Check out the following threads for information about my tests and lots of other discusssion about foil insulation:
http://www.airforums.com/forum...lts-13953.html
http://www.airforums.com/forum...red-13363.html
http://www.airforums.com/forum...cks-30196.html
Malcolm
Only he who attempts the ridiculous can achieve the impossble.
malconium is offline   Reply With Quote
Old 04-12-2007, 08:47 AM   #11
Wabbiteer's Avatar
1972 29' Ambassador
The rule of thirds applies to heat flow: convective, conductive, and radiant each will try to transmit its equal share seeking equilibrium in non-exotic materials. Comparing fiberglass to a radiant barrier? Just look at paths of energy flow, and our lovely Aluminum shells and frames... there isn't good conduction from metal ceiling heat bubble through shell ribs-floor-axles-tires to ground so conduction is null, the aluminum offers no/low texture to increase surface area and make convection a major player so radiation of infra-red is dominant.
Comparing radiant barriers to fiberglass - note sharper temperature gradient per unit of distance; the heat that does push through the foil-bubble-foil will be more energetic compared to heat that has pushed slowly across greater distance of the fiberglass baffles; sort of like a minute hole in a high-pressure tank leaking the same as a larger hole in a low-pressure thank... Does that illuminate the subject in any different ways?
Old 04-12-2007, 01:59 PM   #12
1973 31' Sovereign
Portland , Oregon
Images: 22
I saw a special on the History Channel last night about insulation. It did focus more on foam and fiberglass than it did on reflective types of insulation. It did mention, though, that insulation for space stations was entirely reflective. Evidently with no air in space there is no possibility of heat loss or gain by convection or conduction.
There was also mention of a type of insulation that I had not heard of before. The technology is called gas filled panel insulation. Check out the following sites for some information:
Gas Filled Panels
Technology Transfer
http://gfp.lbl.gov/papers/lbl-38093.pdf
I have not looked into this new type of insulation enough to find out if there are comercially available products that we could use for an Airstream. The claim though is that 1" of gas filled panel insulation can give the equivalent insulation value of 2" of foam.
Malcolm
Old 04-12-2007, 09:20 PM   #13
Central , Mississippi
R(v) value
My system r-vaule would significantly improve if I could get the family to close the darn door.
Old 04-13-2007, 07:31 PM   #14
1973 31' Sovereign
Portland , Oregon
Images: 22
An argument for radiant heating...
Interestingly if your heating system produced direct radiant energy having the door open a lot would not matter nearly as much as it does with forced air heat. Think about the out door heaters that you may have seen and reflect on the fact that they are pretty much all radiant heating systems. Also, think about how nice the sunshine feels on a cold day even though the surrounding air might be pretty cold.
Malcolm
Awning material source NASCAR345 Awnings 6 03-03-2003 11:12 PM
Looking for some good reading material!! John Off Topic Forum 14 02-25-2003 10:02 AM
Seals and Weatherstriping niftypkg Leaks - Weatherstrips, Gaskets, Caulks & Sealants 16 10-29-2002 09:40 AM
Broken Lite Shade Fix wagsrp General Interior Topics 1 10-13-2002 09:11 AM
