Old 05-13-2009, 11:01 AM   #43
bullydogsmom's Avatar
1972 25' Tradewind
old mystic , Connecticut
Mike, you maybe should start a new thread instead of adding to this one, you'll got lots more relies. But one thing I do know is NO NO NO silicone on an airstream. You need to seal the leaks with Vulcum or a product called TremPro.
Does you rot go under the edge of the floor to the outside wall? If it does, you can't just cut out the plywood, or pull it out if it's that rotted and piece it in. You need to remove the lower interior skin and you will see that the plywood slid under what is called the c-channel and it is then bolted through the c-channel through the plywood and through the frame. The floor is a very intricate part of the airstreams structure.
Annette
P.S. Welcome to the world of airstreams!
bullydogsmom is offline   Reply With Quote
Old 05-14-2009, 08:34 PM   #44
1973 31' Sovereign
Portland , Oregon
Images: 22
Mike,
I will second the statement about NO silicon seal ever on the outside of an Airstream. It sticks well enough that it is horrible to get off but not well enough to keep leaks sealed up.
You might want to think twice about treated plywood. I replaced all of the plywood on my floor with treated plywood and very shortly after I did I discovered that the newer varieties of treated plywood have chemicals in them that are extra corrosive to metals, especially to aluminum. I had to take it all out and start over. In the few weeks that it was in place I could already see corrosive action on screws and etc. I used a plastic type of plywood replacement. If you are just repairing parts of the floor I suggest that you just use a good quality regular plywood and make sure your leaks are fixed.
Malcolm
Only he who attempts the ridiculous can achieve the impossble.
malconium is offline   Reply With Quote
Old 05-15-2009, 08:12 AM   #45
Argosy 24
1978 Argosy 24
Zionsville , Indiana
Hey, thanks to both of you for the insight.
I almost made 2 mistakes right off the bat and I've only had this thing a week.
Now I just have to find the right sealants.
By the way, I was thinking of using the silicone from the inside (on the skin), but I guess if it doesn't work outside it won't seal well on the inside either.
Mike Giles is offline   Reply With Quote
Old 05-15-2009, 08:20 AM   #46
Argosy 24
1978 Argosy 24
One more question.
What about Parrbond? (instead of the Vulcum or TremPro) I see they have it at outdoorsmart.
Old 05-15-2009, 08:28 AM   #47
DEITZ645's Avatar
2006 30' Classic S/O
Mohrsville , Pennsylvania
Mike,
Parbond and addionally Acryl-R is good at wicking in tight spots like panel overlaps and between trim and body panels. I think Vulkem is better if you have a larger area to span and want a visible bead of calk like on window and door "eybrows" and where the back of the trailer meet the bumper / storage lockers. I do not know if Out of Doors Mart carries the Acryl-R, but I know you can get it on the Airstream Store home page...
Acryl-R aplicator
Acryl-R
Good luck sealing you leaks, we've all had them.
Carl, Elaine & Finn The Beagle
2006 30' Classic W Slide & Limited Package Katarina
2006 GMC 2500 HD 6.6 Turbo Diesel Crew Cab 8' Bed
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
DEITZ645 is offline   Reply With Quote
Old 05-15-2009, 10:54 AM   #48
kennethowens's Avatar
1975 Argosy 24
Malakoff , Texas
I understand your age situation. Find a "handy-man" fellow in need of work and agree to an hourly wage. Remove the things necessary to get at the rotted area. Then consider the possible solutions to the problem. Posting photo's back into this thread
would be very helpful. Materials that are strong and "cheap" and relatively easy to work....stiff sheet metal and that green colored Fiberglass Bondo. Oh yes....the leak that caused this....find that bugger soon! An '88....21 years old....get a few tubes of caulk while you're out.
kennethowens is offline   Reply With Quote
Goodyear surprise 63air Tires 31 09-27-2006 09:53 PM
surprise!!! rebel beck Off Topic Forum 2 04-02-2006 10:23 AM
The Icky floor surprise eljay Repairing/Replacing Floor &/or Frame 9 11-18-2004 03:58 AM
The '57 was a surprise! Mr. Bliss Our Community 4 04-18-2003 08:32 AM
Yet Another Surprise winner General Motorhome Topics 12 07-24-2002 04:48 PM
