Old 05-23-2004, 06:53 PM   #1
Over59's Avatar
Putnam , Connecticut
Images: 37
Floor Damage
Seems the filler for the water tank on the Caravel has been leaking. At least thats where the damage is. Need to check the outlet connector as well. I suspect the inlet because the floor was sealed with vinyl and caulked on the edges. I think it went down the wall between interior and exterior panels. The wood was very wet and came apart in fibers. I dryed it out and the wood itself has some fiberous body to it. The glue is pretty much gone between the layers. So here's the plan. Fiberglass putty to make a base, sand out the fibers above the base, fiberglass mat and resin to create a new floor in that area. The PO filled the center channel with foam. The frame member is fine on that size. Then finish the cork floor which is what I was about to do when I found the damage.
Got new connector for the tank inlet connection.
ID:	6754   Click image for larger version
Over59 is offline   Reply With Quote
Old 05-23-2004, 06:57 PM   #2
I'd use good quality (not what they sell at Home Depot) penetrating epoxy first. Several applications. It will soak in and give strength back even to the areas back in the shell channel.
Mark
Old 05-23-2004, 07:11 PM   #3
Over59's Avatar
Images: 37
So where do you get it. That's what I was looking for in HD when I bought the putty ect. Which I have other uses for. Are there trade or brand names. I've seen some stuff online but have no experience with the stuff.
Old 05-23-2004, 07:18 PM   #4
Tin Hut's Avatar
2005 28' International CCD
Pagosa Springs , Colorado
floor epoxy
Here's the stuff I used. Seemed to work. I bought the epoxy stuff plus the filler/putty.
http://www.rotdoc.com/
"would you rather have a mansion full of money or a trailer full of love?"
Tin Hut is offline   Reply With Quote
Old 05-23-2004, 08:36 PM   #5
I have been very pleased with Rot Doctor as well -VERY pleased. Really, really pleased. But there are other brands. In fact, I understand Rot Doctor is not a manufacturer, just a packager.
Mark
Old 05-24-2004, 06:03 AM   #6
Over59's Avatar
Images: 37
New plan. Call the Rot Doctor.
Old 05-24-2004, 07:09 AM   #7
Joe Z's Avatar
Go to a marine supply store to pick up the penetrating epoxy. They sell everything you'll need. Joe
Joe Z is offline   Reply With Quote
Old 05-24-2004, 07:29 AM   #8
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
I have only used penetrating epoxy once. As I recall, to be effective, the product must be applied in one application. Penetrating epoxies have a slow cure time to enable them to soak into the wood fibers.
If you apply the stuff in coats, you run the risk of the top layer of wood fibers absorbing the first coat, and effectively blocking the lower layers of damaged wood from absorbing any subsequent coats.
The best thing would be to carefully read the directions that come with whatever product you buy.
Tom
Old 05-24-2004, 07:55 AM   #9
Rot Doctor has the consistency of water. It can, and frequently must be applied multiple times. Some epoxies are thicker and would have too much viscosity to be applied a second time.
Mark
Old 05-24-2004, 09:25 AM   #10
Ken J's Avatar
1956 22' Flying Cloud
Durango , Colorado
Images: 14
The cheapest I found is from Fiberglass coatings - they have a web site and they ship - as I understand it all epoxy is basically the same, just repackaged. I used it on the 59 and was solid as a rock - make sure the floor is VERY dry or you will seal in the moisture
Ken
1956 Flying Cloud
Founder :
Four Corners Unit
Albuquerque National Balloon Fiesta
Rally
Vintage Trailer Academy - Formerly the original
restoration rally
Ken J is offline   Reply With Quote
Old 05-28-2004, 07:11 AM   #11
Over59's Avatar
Images: 37
Found a marine place near me which ups's. Got the CPES (Clear Penetrating Epoxy Sealer) Warm Mixture. They have one for cold down to 28. Soaked the plywood and will start building it up when cured.
Also got a new and correct connector for the inlet and tank.
Old 05-28-2004, 11:05 AM   #12
Stefrobrts's Avatar
1968 17' Caravel
Battle Ground , Washington
Images: 50
I'm interested in seeing pics of the process and after. I have some spots in my Caravel that may be getting the same treatment.
Stephanie
Old 05-28-2004, 12:52 PM   #13
59toaster's Avatar
1959 22' Caravanner
Atlanta , Georgia
Images: 22
As bad as that it...I'd be replacing the wood. These patch products are doo for small areas but thatl looks like the better part of the width of the coach and a good 2-3 ft wide. That is a major loss of structure and the coach is in a weakend state because of it.
Money wise your going to spend more on sub standard "patch" than the wood to repair it correctly is going to cost. Yes, it's a lot of labor but it guaranties the coach will make another 30+years down the road. The coach as it it now is going to be very prone frame drop and speration problems because of a weak condtion between where the U=Channel is fastend to to the deck and the deck is fastend to the frame.
1959 22' Caravanner
1988 R20 454 Suburban.
Atlanta, GA
59toaster is offline   Reply With Quote
Old 05-28-2004, 03:05 PM   #14
Over59's Avatar
Images: 37
The wood fiber is still tough. The glues gone. The area is about curb side to opposite frame rail on street side. It's 9 inches at the widest which is where the water inler for the tank was. In that area about 4 inches for floor is gone in the channel. I've put on the PCES and awaitng cure. About a week. I'll reaccess then.. May have to replace the curved part of the floor if not firm. Need the stuff for some house detail repair anyway and will do the 59 overlander floor from end to end with the stuff prior to an epoxy painting. A project now on hold.
