Old 05-01-2011, 08:47 PM   #1
surfpod's Avatar
1976 23' Safari
1962 22' Safari
1961 16' Bambi
Philly burbs , PA
Floor channel size when installing 3/4" plywood?
Hi All,
I'm the proud owner of a 1976 23' Safari recently purchased, ending a 3-4 year search. I have learned a ton from this Airstream community forum. Thanks for sharing your knowledge! I've embarked on a total shell off resto to my pod. So far, so good. My question concerns fitting floor channel. When the floor has been reinstalled using 3/4" plywood vs. original, how does the floor channel fit. Is it wide enough to up to 3/4" thickness?
surfpod is offline   Reply With Quote
Old 05-01-2011, 08:56 PM   #2
CanoeStream's Avatar
St. Cloud , Minnesota
On my '74 Argosy, I used 19/32" inch solid ply underlayment. Even that is more than the perimeter channel is built for -- had to sand the edge of my 19/32" to fit it in. 1/2" is what was originally used.
5 meter Langford Nahanni
Old 05-01-2011, 09:03 PM   #3
surfpod's Avatar
1976 23' Safari
1962 22' Safari
1961 16' Bambi
Philly burbs , PA
It looks like I may have use a router to reduce the thickness of my 3/4" plywood to accept the floor channel. Thanks!
Old 05-01-2011, 09:04 PM   #4
x
XXXX , XXXX
My 73 was 3/4" plywood and the new metric size was a little tight but did fit.
wasagachris is offline   Reply With Quote
Old 05-01-2011, 09:15 PM   #5
surfpod's Avatar
1976 23' Safari
1962 22' Safari
1961 16' Bambi
Philly burbs , PA
I read your restoration thread with great interest, learning what I was about to encounter! Great detail, great pics. It's helped me a lot. Thanks!
Old 05-01-2011, 09:17 PM   #6
x
XXXX , XXXX
surfpod you're welcome feel free to brain pick any time you need. Either in a thread or by PM if yoy want.
Old 05-02-2011, 09:01 PM   #7
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
Hi All. I'm working on my floor in the front section of an '85 Excella. The channel appears to be 5/8" but the subfloor I'm removing looks more like 3/4". I may try the router to take a bit off the edges to slide into the channel. I'm removing a section of severly rotted wood due to a leaking window seal. It's a real bear to get the old wet, swelled wood out of the channel but with some effort I've been successful so far. Fortunately I don't need to do too large of a section. Is marine plywood going to be overkill for this job, or should I go with just an exterior grade.
Thanks all,
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 05-02-2011, 11:19 PM   #8
1985 31' Excella
Fresno , Texas
Roger I uncovered my outriggers in the front are rear early last week and will be replacing 6 but could have probably got away with replacing only 2. I found the OSB had expanded or swollen over time to just under 3/4" It is stamped 5/8". Mine is a early model '85 and I plan to use the 23/32" for my repair. I should be within a 32nd of the original flooring. I also found that Airstream has planed down my OSB to get the channel on under my battery box on the curbside over to the side wall I haven't done a close inspection as to why yet since I don't have to replace that area.
Hope things go good with your project.
Wes
Wsmith is offline   Reply With Quote
Old 05-03-2011, 12:25 PM   #9
retired USA/USAF
2001 30' Excella
Thanks Wes. The OSB was really tough to get out of the channel. I ended up drilling it repeatedly and just eating away with a screwdriver and other tools. I removed all the subfloor that I plan on replacing this morning. I don't plan to replace any of the frame members but I am planning to paint them with the POR-15 stuff to inhibit any further rust. The area's that were kept dry are in fine shape. In the areas that had been wet do show some rust but not the extend requiring them to be replaced. I'm looking at an area from the door in almost 4' and forward almost to the battery boxes. Something tells me I should go farther but not at this time.
3/4" plywood seems to match in thickness nicely with the OSB that it will butt up to. So I think that's what I'll go with and use a router and take the thickness down a but along the edges where they fit into the channels. So far it's progressing nicely. I need to order some of the self tapping screws for the flooring and some rivits to put it all back together.
Appreciate your help and advice
Roger in NJ
TAC - NJ 18
Window weather stripping size / dimensions? AirHome Leaks - Weatherstrips, Gaskets, Caulks & Sealants 3 03-14-2011 09:58 PM
Tires and tire size KyMoonshine Tires 5 03-08-2011 04:28 PM
What size tank Brianv512 Waste Systems, Tanks & Totes 2 02-21-2011 10:09 PM
28' Ambassador v. smaller size Airstream Nigel Member Introductions 13 01-25-2011 04:34 PM
waterlines size qc1500 Fresh Water Systems 8 01-11-2011 06:04 PM
