Old 08-05-2012, 05:37 PM   #1
1969 27' Overlander
Esbjerg , Jylland
Send a message via ICQ to Luc_DK Send a message via Skype™ to Luc_DK
Floor AS 1969 Overlander
Hi
I have an (what i think) an inspection hole in the floor in the bathroom, i think it's for the gas water heater, which is NOT connected anymore.
is't a problem to cover the hole ?
i'm mounting new vinyl and dont want to cut a hole if i dont need it...
regards
Peter
Luc_DK is offline   Reply With Quote
Old 08-06-2012, 11:13 AM   #2
1969 27' Overlander
Turbotville , Pennsylvania
That is a vent for the furnace. There should be another one just like it somewhere in the front of the trailer, too.
JRookie is offline   Reply With Quote
Old 08-07-2012, 03:47 AM   #3
1969 27' Overlander
Esbjerg , Jylland
okey vent for the waterheater, it's disconnected and an electric waterheater is installed, so i guess i can cover the hole with new vinyl floor without any problems then ?
yes there is also one inside the kitchen cabin.
/Peter
Old 08-07-2012, 09:13 AM   #4
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Water heaters vent to the outside of the trailer. As previously mentioned, it ismost likely a vent for the furnace.
Richard
Old 02-15-2013, 09:19 PM   #5
KAYAKAMPERS's Avatar
1966 26' Overlander
Stone Mountain , Georgia
What you have is your cold air return vent. I'm not an expert, but to ensure your furnace works correctly, it needs the cold air returns that Airstream put in these units.
_______________________________
Beth Wallace & Chris Sanor
1966 26' Overlander International
Towed by 2016 Ford F-150
Tin Can Tourist
TAC #GA-27
AIR #34930
KAYAKAMPERS is offline   Reply With Quote
Old 02-15-2013, 10:31 PM   #6
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
The furnace takes cold air in at the furnace.
That's a warm air vent that heats the bathroom. The front vent heats the front.
They are covered with a grill-like device called a floor register.
Vaughan
Old 02-16-2013, 06:13 AM   #7
1966 26' Overlander
I guess my original owners manual for my 66 overlander is not right! In houses that size is always a floor register but not for our Suburban heater.
Tin Can Tourist
TAC #GA-27
AIR #34930
Old 02-16-2013, 01:11 PM   #8
1983 34' Excella
1967 24' Tradewind
Images: 32
Well, I wasn't going by an owners manual. In my 67 Trade Wind, hot air came out of those.
Besides, an Airstream is too small to need return ducting. When the hot air is blown to the ends, the air will recirculate.
Vaughan
