Old 10-30-2006, 03:52 PM   #1
soldiermedic's Avatar
Profile:  1975 29' Ambassador
O'fallon , Missouri
Question Floating Floor/Laminate Question
I have noticed a great deal of people are going with a Pergo or Armstrong laminate floating floor system. I went to Lowes and Home Depot today and was told that I would be crazy to do so since it gets cold here in Missouri. I can't imagine that it would be such a big deal. So...will having such a floor system in the midwest USA cause problems for me with the floor life? Also, would you remove all of the interior furniture (Dinette, Beds, etc), and place underneath them, or would you but up against the edge? Most companies suggest using quarter round to cover the edge spacing, but I cant see how that works with an A/S since you really cant nail into the metal skin.
Comments, suggestions, experiences of your own?
soldiermedic is offline   Reply With Quote
Old 10-30-2006, 04:02 PM   #2
GA Airstreamer Air_005
Profile:  North , Georgia
Yes remove the furniture, and anything else that is not a problem to remove. It will make the laminate look better and go down easier.
As for the cold effecting it, remember the guys at HD and Lowe's are mostly retirees who have limited knowledge, especially about RV's. Not all mind you, but many. They may know lumber or paint from their practical experience.
Install the flooring sideways ( across the width), don't use glue, and remember to leave a small space at the wall for heat expansion. You can use quarter round, you just nail it into the subfloor. I did my 78, it looks great and was very inexpensive. After camping you sweep it out, and you're done.
Rallys twice a year..Lots of fun, food, and aluminum.
http://groups.yahoo.com/group/gaairstreamcampers/
http://airstreampassion.blogspot.com/
My Music Site:
HTTP://ALANDAVIDSONGS.COM
Old 10-30-2006, 04:03 PM   #3
here ya go---
My Music Site:
Old 10-30-2006, 04:04 PM   #4
Happycampers's Avatar
Profile:  1979 30' Argosy
Peterborough, , Ontario
Hello.. We put Armstrong laminate flooring in our other Argosy and loved it so much we are putting the same in our present Argosy.. this is exactly the same laminate that is in some $400-500,000 motorhomes.. we live in Ontario and left a piece out for than 18 months ago .. and it looks just the same as when it came out of the box... The store we bought it from was so impressed that they have a pic of it..
Marvin & Annie
Toby & Niki (fur babies)
1979 Argosy 30
WBCCI 10103
2005 F250 Lariat Power Stroke Diesel Crew Cab 2wd
"Happiness is a warm Puppy" Charles Schulz
Happycampers is offline   Reply With Quote
Old 10-30-2006, 04:06 PM   #5
The best kind to put in is a click flooring.. and put caulking around the perimeter when you are finished.. Will try and post a pic
Marvin & Annie
1979 Argosy 30
WBCCI 10103
Old 10-30-2006, 04:08 PM   #6
Profile:  1971 31' Sovereign
Joseph , Oregon
Why would you run it sideways compared to the length of the AS
Larry and Nicole
trea is offline   Reply With Quote
Old 10-30-2006, 04:37 PM   #7
O'fallon , Missouri
Here is the front of my Safari. If I remove this dinette, and the goucho, and put the flooring underneath it, I would not be able to put the screws back into the same place. Should the old holes be sealed, and what would you use??
Old 10-30-2006, 06:20 PM   #8
Excella CM's Avatar
Profile:  1978 31' Excella 500
Venice , California
We just installed costco pergo style laminate in the rear 2/3 of the Silver Pullit. They suggest (demanded) 3/8" clearance all around, but I figure that's for a 12' run (average room) so I diminished that by 4/5. Installed it as a floating floor on their proprietary plastic foam bedding. Didn't put it under either rear bed. Went down easy, looks great-as for the rest-time will tell, but we're optimistic.
"Not all who are lost are wondering" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 10-30-2006, 06:22 PM   #9
O'fallon , Missouri
Excella CM, what are you covering your edges with to dress it up?
Old 10-30-2006, 08:13 PM   #10
peegreen's Avatar
Profile:  1998 31' Excella 1000
South Berwick , Maine
I installed mine lengthwise, search the forums for all sorts of pics and opinions. It gets well below 0F in Maine and the interior well over 100F when all closed up sitting in the summer sun. Looks like the day it was installed. I used the quarter round for the brand of laminate - the Home Depot special of the month. 15 year warranty for home use which equates to a millenium for RV use considering the number of nights out in a typical year unless you're a full timer. Furniture is not always that easy to remove, but some aluminum extrusions that were screwed through the carpeting were removed. I drilled a large hole through the laminate before screwing these pieces back down so as to allow the floor to 'float' around the screws and underneath the aluminum plates and not buckle.
WBCCI 24291
New England Unit
Metropolitan NY Unit
peegreen is offline   Reply With Quote
Old 10-30-2006, 08:22 PM   #11
Tarheel's Avatar
Profile:  2001 34' Limited S/O
Moyock , North Carolina
Images: 21
I've had mine in for several years. It has seen the hot humid conditions of the North Carolina coast, the arrid Southwest desert, Cold in the Rockies and everything inbetween Salem Oregon and North Carolina. I have had no problems with the flooring. I did nail down the 1/4 round and that was a mistake, it should be glued. The flooring (laminate from Sam's Club) looks like it was put down yesterday.
Keep the shiny side up.
WBCCI # 3485
Region 3 2nd VP
Past President Tidewater Unit 111
visit tidewater Virginia's web page @
www.tidewaterwbcci.com
Rick Bell in "Silverbell"
Tarheel is offline   Reply With Quote
Old 10-30-2006, 08:33 PM   #12
Fyrzowt's Avatar
Profile:  2000 25' Safari
Templeton , California
Images: 8
Tarheel,
Why was nailing your trim a mistake? My PO nailed mine, wondering if I should something with it.
Fyrzowt is online now   Reply With Quote
Old 10-30-2006, 08:43 PM   #13
O'fallon , Missouri
Tarheel,
When you say you are nailing it I assume you mean into the subfloor and not the side of the aluminum skin right?
Old 10-30-2006, 09:01 PM   #14
Profile:
I have had laminate flooring (Alloc brand) in my coach for three years. It still looks like new, right here in Missouri.
You can choose to install it front to back, or side to side, as you wish. I installed mine lengthwise, but would not do so again as it is far easier to install side to side.
To keep from splitting or buckling it does need to "float", so you do not want to install cabinets on top of it, thereby rendering it immobile. As noted above, the runs in our coaches are much shorter than the manufacturer anticipates, so you can reduce the recommended gap at the ends - by half if you go side to side. There will be NO gap in the front after the first time out, so there is no point in installing it with any gap in the front.
I was unwilling to use it in the bathroom, but others have.
I wanted to be able to take mine up, should the need arise, so I installed my quarter round with countersunk brass screws into the sidewalls. I think there is a photo of this in the forums archives somewhere.
Mark
'85 Sovereign, 25'
Pingbacks are On
Question re new floor fitting on our 1958 Traveller williamhenshall Repairing/Replacing Floor &/or Frame 9 06-30-2004 03:08 PM
Skylight part question ColtSAA45 Roof Vents, Skylights & Fans 3 04-22-2004 08:05 PM
Number Decals Question wagsrp Airstream Motorhome Forums 7 10-11-2002 08:18 AM
Battery Dead/Power jack question jcanavera Jacks, Stabilizers, Lifting and Leveling 34 08-16-2002 01:51 PM
Tire sizing question caadoptees Tires 5 07-02-2002 10:19 PM
Cooking Forum - Sailing Forum - Early Retirement
Airstream Trailer Forum - Aquarium & Reef Forum
Royal Forum - Book and Reader Forum - Yoga Forum
Volkswagen Touareg Forum - Jeep Wrangler Forum
Whitewater Kayaking & Rafting Forum - Yoga Forum
Interference - U2, Pop Culture & Social Responsibility
