Old 11-05-2006, 02:46 PM   #43
Profile:  1971 31' Sovereign
Joseph , Oregon
We have purchesded laminet flooring for our A/S and will be laying it length wise. It is a floating floor so when you lay it down I would say anything that is permanent should have the floor cut around it to let it float. There will also be a 1/4 inch expansion around the walls and any cabinets. This will be covered with some type of trim when done.
The flooring we purchased is 7mm (1/4 in) thick.
Larry and Nicole
trea is offline   Reply With Quote
Old 11-05-2006, 04:46 PM   #44
Happycampers's Avatar
Profile:  1979 30' Argosy
Peterborough, , Ontario
Great Pumpkin, Yes it is a laminate, the sheets are 2ft. by 4ft. the make is Armstrong so any Armstrong dealer can get it. It is a little pricey at $5.99 Canadian per square ft. We have sold that trailer but are going to put the same floor in our 30 ft. Argosy. It holds up really well even with 2 dogs. I left a cut piece outside for 1 1/2 years and it didn't warp or fade. The dealer was so impressed he has a picture of the floor and a piece of the floor I left outside. That isn't a real good picture, it really looks like slate. If you want more info or some better pictures pm me. Marvin
Marvin & Annie
Toby & Niki (fur babies)
1979 Argosy 30
WBCCI 10103
2005 F250 Lariat Power Stroke Diesel Crew Cab 2wd
"Happiness is a warm Puppy" Charles Schulz
Happycampers is offline   Reply With Quote
Old 11-05-2006, 05:58 PM   #45
GA Airstreamer Air_005
Profile:  North , Georgia
as for floating, I put the laiminate under my gaucho and then screwed it back down. So the floating is not happening under it anyway. So far no problems, and the weather here has varied from 95 degrees to the upper 20's last week, no ill effects. The rest of it may be "floating" to some extent, but the quarter round trim is nailed down on the sides. I had a similiar thing with the cork in my moho, and that never buckled at all, and was glued in several areas..
Rallys twice a year..Lots of fun, food, and aluminum.
http://groups.yahoo.com/group/gaairstreamcampers/
http://airstreampassion.blogspot.com/
My Music Site:
HTTP://ALANDAVIDSONGS.COM
Pingbacks are On
Question re new floor fitting on our 1958 Traveller williamhenshall Repairing/Replacing Floor &/or Frame 9 06-30-2004 03:08 PM
Skylight part question ColtSAA45 Roof Vents, Skylights & Fans 3 04-22-2004 08:05 PM
Number Decals Question wagsrp Airstream Motorhome Forums 7 10-11-2002 08:18 AM
Battery Dead/Power jack question jcanavera Jacks, Stabilizers, Lifting and Leveling 34 08-16-2002 01:51 PM
Tire sizing question caadoptees Tires 5 07-02-2002 10:19 PM
Cooking Forum - Sailing Forum - Early Retirement
Airstream Trailer Forum - Aquarium & Reef Forum
Royal Forum - Book and Reader Forum - Yoga Forum
Volkswagen Touareg Forum - Jeep Wrangler Forum
Whitewater Kayaking & Rafting Forum - Yoga Forum
Interference - U2, Pop Culture & Social Responsibility
Search Engine Friendly URLs by vBSEO 3.2.0 RC8
