Old 11-17-2015, 02:21 PM   #1
Savannah , Georgia
Flipping the frame
I m in the process of a shell off restoration of a 66 Overlander. I read a thread a while back where the owner flipped the frame to install the insulation and belly pan. I cannot find that thread, Can someone help me out or are there any tips or other threads I should check out?
Glt12 is offline   Reply With Quote
Old 11-20-2015, 07:37 AM   #2
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
Well, if you look at post #9 of the following thread, you can see me flipping my frame using the gantries that were built to lift the shell and 3 chain hoists.
http://www.airforums.com/forums/f36/...on-115765.html
The way I did it, is I used a loop of high strength webbing inside the A-frame and attached it to a single chain hoist. The way this worked, the hook of the hoist could slip around the circumfrence of the loop as the frame rotated 180 degress, thus, I didn't have to create any fance pivot, and there was very little chance that my hoist could lose its connection with that end of the frame.
On the rear end of the frame, I used two hoists that had a common anchor at the center of the gantry cross beam. They were each connected to the far corner of the frame, again with chain or webbing attached inside the rear cross member so that they could not slip off and allow the frame to drop.
To lift and flip, I essentially lifted the entire frame up to a level of about 4 ft off the ground, and then I started to raise one of the rear corners, while slacking off on the other to execture an control the rotation. Once the fram was hanging vertically (ie., entirely from one of the hoists), I would disconnect the lowermost hoist, flip it around to the other side, and then reverse the process until the frame was horizontal again, but upside down.
good luck!
Old 11-22-2015, 04:49 PM   #3
Airstream installs many parts with the frames flipped.
Then they flip them back on the floor because the frame also, then has wheels.
Old 11-22-2015, 07:09 PM   #4
DFlores's Avatar
1968 22' Safari
See post #43 to see our photos about installing insulation while frame flipped
http://www.airforums.com/forums/f192/david-and-dianes-68-safari-milestone-100750.html
Sent from my iPhone
David & Diane
DFlores
David & Diana
DFlores is offline   Reply With Quote
Old 12-01-2015, 12:04 AM   #5
1968 22' Safari
Tulsa , Oklahoma
photos of flipping
https://www.flickr.com/photos/453877...57649328601853
I saw this link from the FB group Airstream Addicts and it shows an off frame restoration and it's flipped over to put the new belly pan and insulation in and then flipped back over. It's scary!
LSDPhotos is offline   Reply With Quote
Old 01-03-2016, 09:35 PM   #6
GuitarmanFL's Avatar
1972 27' Overlander
Orlando , Florida
Hmm. That would be soon much easier than being on your back!
GuitarmanFL is offline   Reply With Quote
electric griddle - flipping breaker funkill Stella's Kitchen 5 07-03-2010 05:11 AM
Flipping Zip Dee Up Ganglin Awnings 7 08-08-2009 08:33 PM
Flipping axle for lift nmhuntr Axles 7 07-01-2009 12:50 AM
2007 Dometic AC is flipping the breaker oceanair Furnaces, Heaters, Fireplaces & Air Conditioning 8 06-20-2009 05:03 AM
Air conditioner breaker flipping cowpokemon1 Furnaces, Heaters, Fireplaces & Air Conditioning 8 05-27-2008 01:45 PM
