Old 01-04-2015, 03:04 PM   #1
Brasslens's Avatar
1957 22' Flying Cloud
Mississauga , Ontario
Finding floor bolts/screws without removing vinyl flooring
I wanted to share a technique that I'm using to find screws underneath the vinyl flooring.
Tools:
- 1/2 inch neodymium magnets wrapped in ductape so you can easily clean them
- 3 inch hole saw
- hammer and chisel
Start of by running the magnet up and down the floor to find your first bolt. Mark it and cut around the mark using the hole saw just enough to remove the vinyl layer. You should then find the bolts/screws your looking for!
ID:	229797   Click image for larger version
ID:	229799   Click image for larger version
Brasslens is offline   Reply With Quote
Old 01-04-2015, 04:11 PM   #2
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Just my thought! Great minds.... Oh, maybe not. ��
Peace and Blessings..
Channing
WBCCI# 30676
cwf is online now   Reply With Quote
Old 01-04-2015, 04:19 PM   #3
Brasslens's Avatar
Hehe it works great! Good luck on your restoration
Old 01-04-2015, 04:59 PM   #4
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
I used on of the old style magnet stud finders. The el cheapo one.
Aaron
WBCCI #XXXX AIR #2495
Old 01-04-2015, 11:25 PM   #5
Brasslens's Avatar
Great idea! Now that the floor is out, I found that the rear end is sagging 2" on one side.. any tricks to fixing this?
Old 01-05-2015, 04:48 AM   #6
Baltimore , Maryland
Campfire pisser here. Most will say nothing;
Those tiles are not vinyl. They contain a small level of asbestos and you did exactly what you not supposed to do with them, you made them friable. The fine dust the hole saw created is very dangerous. It is all over the place inside your trailer now. I strongly suggest you carefully vacuum every square inch of the interior before you go any further. Asbestosis is no joking matter and it has only one cure.
I think this technique you used was done to avoid the belly pan removal. Bellypaniphobia is rampant in the home restorer world. Removing the belly pan would have allowed you full access to the bolt from below. When attacked from below, a pair of vise grips will break the bolt off in about 5 seconds time. It also makes putting in the new floor correctly so much easier. You will probably respond that you are using self drilling screws to install the new floor. This will work fine(though not recommended or condoned by FTW) but will not allow you bolt the channel to the frame members around the perimeter of the sheet.
As for the sag, use a jack stand to put it back where it should be before you bolt/screw the new piece into place.
Old 01-05-2015, 10:30 AM   #7
Brasslens's Avatar
Thanks for the heads up Frank! The PO installed the new tiles over the summer and could not complete the restoration. I hope the newer ones don't have asbestos..
Floor replacement without bolts jtsanchez Repairing/Replacing Floor &/or Frame 8 03-01-2012 10:51 AM
lower Hot water cover screws, bolts ? Bob Sheridan Vintage Kin 2 10-12-2011 12:21 PM
Help with removal of rusty Bolts/Screws KATYBELLE Repairing/Replacing Floor &/or Frame 11 02-09-2011 08:26 AM
Where to put j bolts, screws and adhesive JoePfznik Repairing/Replacing Floor &/or Frame 1 12-17-2009 07:29 AM
removing floor without removing shell nevisstudio Repairing/Replacing Floor &/or Frame 11 07-24-2005 10:47 PM
