Old 10-11-2006, 06:58 PM   #1
Silver Mist
LI Pets's Avatar
Riverhead , New York
Smile Fiberglassed floor
After stripping out most of the mess pic 1
The floor which I believe is the weakest point in all A/S, needed to be water proofed from leaks from above.
Also the floors need to be strengthened; I removed a rotted section, refastened with self tapping screws here and there.
I used epoxy resin and one layer of 6 Oz fiberglass cloth, just like a boat.
It only added 15 lbs, cost about $140 in materials. No odor or special equipment.
Time 4 hours.
The results are amazing I can walk anyplace and the flex is gone, rock solid.
Next 1/4" Promax insulation R-14 will be laid on top of the floor then, Pergo.
All the old insulation under the floor (the source of many problems) was removed.
Name:	mess (Medium).jpg
ID:	26889   Click image for larger version
LI Pets is offline   Reply With Quote
Removing the body shell and installing new floor completely - any one done this? williamhenshall Repairing/Replacing Floor &/or Frame 11 03-13-2006 11:21 AM
Question re new floor fitting on our 1958 Traveller williamhenshall Repairing/Replacing Floor &/or Frame 9 06-30-2004 03:08 PM
When lacking a floor to make a template... JrnymnJay Repairing/Replacing Floor &/or Frame 6 11-30-2002 06:28 PM
Front floor area and rebuilding dresser jeanarlene 1969 - 1973 Safari 10 09-05-2002 11:11 AM
Total floor replace 74Argosy24MH Repairing/Replacing Floor &/or Frame 1 06-27-2002 04:05 PM
