Sorry to be the bearer of unfavorable theories, but I have the same model as you and suffered the same symptoms as you and discovered that the fill hose to the water tank had been leaking for two years undetected. The water would run down the wall and get between the flooring and the subfloor and completely rotted out the subfloor. Unfortunately, this discovery was made 10 months out of warranty and the mothership refused to have anyting to do with the repair . The good news is the repair was fairly straight forward, the good folks at C & G in Bellflower were as gentle as they could be with pricing and the workmanship was top rate. A word of warning to all Bambi owners, keep checking the connectors of the fill line and the overflow line to the fresh water tank for leaking. Best to check after a long tow as the water has been sloshing about.
