Old 07-29-2008, 02:01 PM   #1
MyFirstStreamer
Zstream's Avatar
Indiana , Indiana
Question Factory tour ... Reflectix under subfloor?
I went on the Airstream factory tour yesterday and was intrigued to see that when assembling the new trailers they put down a foil like insulation under the sub-floor and the pink insulation in the walls.
I see Home Depot sells a product called Reflectix. Does anyone have any experience using this foil type insulation under the sub-floor? Is the R factor of Reflectix high enough to use under the sub-floor or is AS Corp using something else? If Reflectix is ideal for this application, do you also add the pink insulation to the belly pan/frame?
Tks, Z
Zstream is offline   Reply With Quote
Old 07-29-2008, 04:21 PM   #2
Tramp Streamer
ArtStream's Avatar
1995 28' Excella
Artist , at Large
Images: 65
Hi Z!
Many of us here on the forum are replacing the "Pink mouse stuffing" with Reflectix under floor and in the walls. No one would recommend putting Pink back under the bellypan.
But you can add it to the Reflextix in the walls.
Searching the forum should yield "True stories" and applications.
PS, and welcome to the forum!
Michael
ArtStream is offline   Reply With Quote
Old 07-29-2008, 04:54 PM   #3
MyFirstStreamer
Zstream's Avatar
Indiana , Indiana
Do you put down anything on top of the frame before you lay down the Reflectix's? Tks, Z.
Old 07-29-2008, 06:00 PM   #4
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
When I removed the bellypan at the rear of the trailer to repair a gaping hole, clean up the frame and POR the rear frame rails, I tore out the remaining pink insulation from the last cross member to rear compartment. I had to choose between the thick blue foam insulation board and Refectix. I chose 4 alternating layers of the stuff with the first layer glued and stapled to the underside of the floor.
I just cut out the outrigger behind my street side rear wheel and removed the pink insulation hanging down. I plan on sticking in 2 layers of 3 inch pink insulation in between a layer of Reflectix on the bottom and one on top. The idea is to try to keep water and dirt from the pink insulation and give additional insulation under the water heater and bed area without extra weight. I will probably add additional layers of Reflectix in the side/rear storage compartment along the wall because this is the corner bed area prone to drafts.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 07-30-2008, 05:01 AM   #5
boatdoc's Avatar
1973 Argosy 26
Norristown , Pennsylvania
Tks, Z
Hi Zstream; I have used Prodex, much the same as Reflectix throughout the whole 26' restored Argosy. However, I have glued 1"x2" urethane strips onto the sub floor underside. Cutting the Prodex by 3" oversize I have overlapped it onto the frame members attaching it with 3M 5200 Fast Cure to the urethane strips and frame. Prodex has advertised "R" value of 14.7. Added air space between bubble foil and sub floor adds about two points in "R" value. I did the same thing in the walls using 1/2"x2" urethane foam strips in order to create air space on booth sides. I have brought the Prodex along the ribs toward the inner skin trimming the excess 1/8" high past the rib. This way the inner wall skins sealed the cut edges of Prodex. My 15000 BTU Carrier freezes me out at the lowest setting in 95+ degree direct sun. Thanks, "Boatdoc"
boatdoc is offline   Reply With Quote
floor, insulation, overlander, reflectix
Factory Tour azflycaster Off Topic Forum 2 07-01-2007 11:39 AM
Airstream Factory Tour Silvertwinkie Our Community 73 01-10-2007 05:20 PM
Factory Tour scf31 Our Community 11 02-19-2006 08:48 AM
Airstream Factory Tour Road82 Our Community 5 11-04-2005 02:15 PM
Factory tour ALANSD Airstream Motorhome Forums 14 06-26-2003 05:29 PM
